2000 3x00 top end question
  • gboogie99
    they still can't catch me
    • Nov 2005
    • 348
    I found a 2000 lumina at the local pull a part with the entire top end intact, is it worth my time to pull all of it? I figured I'd only need the uppermanifold, fuel rail and throttlebody to upgrade my 1995 3100.Total cost about 80 bucks. Or should I pony up 200 bucks and take the whole engine and figure out why it ended up in the junkyard?
    help...
  • SHOoff
    • Jul 2005
    • 356
    You want the heads and all. The 00+ has the larger ports and valves in the heads.
    97 Cavalier RS
    3400, Isuzu MK7
    • El_Diablo
      STFUniversity
      • 917
      it would prolly be worth it to pull the whole engine if its not the reason the car is in there
        • 9191
        You would also need the lower manifold as the newer plenum will not bolt to the old-style lower manfiold.
        • AaronGTR
          boost lover
          • Jan 2004
          • 708
          Yeah, I say grab the whole engine if it's not too much $$$ and swap over the heads, upper and lower intakes, TB... the whole shot. You'll need all those parts to work together and you'll get the most gain from it that way.
          '97 Grand Prix GT 3800 (sold)
          Gotta love boost!
          • Guest
            I'm throwing another vote in for grabbing teh whole engine.
            • gboogie99
              • Nov 2005
              • 348
              yeah, i might just do that, this way I'll have the top end I need and all the parts for the OBD II swap if the engine isnt worth rebuilding
              but if it is I'll probably just swap it in after its turbo'd
              betterthanyou hurry up with some flanges!!!!
              • gboogie99
                • Nov 2005
                • 348
                well, i guess i'll be getting the whole engine seeing as how my water pump locked up on I-77 yesterday and took the engine with it.
                • Syn
                  The Master Piece
                  • Oct 2005
                  • 599
                  wow what luck man
                  • torq455
                    If I only had money!!!
                    • 1615
                    Well that's different.
                    Andy
                    fastest 1/8: 10.19@ 67.17
                    fastest 1/4: 16.16@ 82.70
                    • El_Diablo
                      STFUniversity
                      • 917
                      back when my mom had what is now my car, we had to swap in a new engine due to a seized oil pump which pretty much welded the pistons to the block
                      why couldn't chevy put an oil pressure gauge in the malibu?
                      • TheProfessor
                        • 869
                        yeah get the whole engine..............even if the internals are junk
                        it will be fun to take apart
                        I Like V660s
                        Does Chevy make beer
                        ~Jayme~
