Will these work?
  • Nightingale
    • Apr 2005
    • 259
    Will these work?
    Just wondering if Crane Gold race rockers from a 4.3L 90* v6 could work with the gen 2 aluminum heads or even gen 3 aluminum heads(of course with a stud conversion cause these come with 3/8"). Thanks for looking.
    98 camaro swapping in lz9 th400 setup
    LZ9 specs: (Subject to Change work in progress)
    4.0L(after bore 3.917 and stroke 3.3485),carrillo sbc rods(narrowed),wiseco custom forged pistons 8.5:1 CR, TCE Double Roller timing chain, gen 3 cam, P&P heads, headers 1 3/4 primaries into 3-1 collector, and going to run ms2.
  • v6h.o.
    • 1418
    As long as they are the Narrow body style designed for centerbolt v'covers.
    Colin
    • Nightingale
      • Apr 2005
      • 259
      Heres the exact info on these rockers http://www.cranecams.com/?show=brows...umber=10758-16. From the description it seems like they should work fine other than needing possibly some clearencing, and the stud conversion.
      • geoffinbc
        Iron Head Enthusiast
        • 5831
        Yea they will work. No clearancing is required on Gen I or Gen II. Gen III will require intake grinding.
        I am guessing you are getting these rockers used? Because if you are buying new I would suggest the COMP Pro Magnums because they have a much smaller back section and I am willing to bet they will not require any clearancing on Gen III
        • Nightingale
          • Apr 2005
          • 259
          Yea I was looking at both sets and I have found a set of each used. I was just looking into getting the gold race because they have the full roller fulcrum.
          • geoffinbc
            • 5831
            So do Pro Magnums http://www.compcams.com/Technical/Cu...g/HTML/311.asp
