Difference in rocker arms? 2001 Vs 2003
  • onefastV6
    • Sep 2005
    • 880
    I remember reading that the rocker arm stud changed in 2003 or something along those lines. Does this mean the rockers are different?
    Also I have heads that are suposed to be off a 03, to take the rockers off I used a 5/16" socket. Casting # on the heads are 24507487 Can anyone confirm what year the heads are off of from the casting #?
    Attached is a picture of the measurements of the stud that I took.
    [/img]
    2000 Grand Am GT
    2011 Chevy Impala
  • v6h.o.
    • 1418
    Yes they changed the bolt size from an M10 thread bolt - 10mm top nut. 2002 and previous style.
    to the newer style which is a M8 thread (smaller sized bolt what you have there) with a 8mm top nut (8mm is the same a s 5/16ths in terms of socket sizes)
    The rockers are obvously different due to the trunion bolt hole size to the corresponding bolt size.
    Colin
    • onefastV6
      • Sep 2005
      • 880
      Thanks, the reason I am asking is that I contacted ZZP about making us rocker arms that have higher ratio.
      The e-mail I got back from Zoomer said " If you could send us a stock rocker with a note, that would be helpful"
      Did anything else change other than the size of the stud on the rocker arms? I am going to go ahead and send one in to them, along with a note of the changes that were made between the different years.
      2000 Grand Am GT
      2011 Chevy Impala
      • geoffinbc
        Iron Head Enthusiast
        • 5831
        Nothing changed. They are still the same ratio.
        • BlackJack
          Jack Wagon
          • Sep 2005
          • 84
          do let me know if they come up with a 3400 specific hi-perf rocker, preferably needlebearing full roller.
          • El_Diablo
            STFUniversity
            • 917
            i thought we already had a pretty good ratio
            • geoffinbc
              • 5831
              Well more would mean more lift and effective duration without a cam change. A little boost in performance for little effort.
              • eliteweapons
                • Apr 2005
                • 185
                Any news on different ratio rockers yet?
                95 Beretta Z-26
                Don't need nitrous to go fast.
                Global peace through deadly force!
                • onefastV6
                  • Sep 2005
                  • 880
                  Not yet, I just got back to school and haven't sent it out yet. I am heading to the post office tomorrow so I will see if I can't go ahead and send it out tomorrow. I also might contact intense as they currently have Harland Sharp making thier rockers in a 1.9 ratio.
                  2000 Grand Am GT
                  2011 Chevy Impala
                  • AaronGTR
                    boost lover
                    • Jan 2004
                    • 708
                    I wouldn't recommend that unless you make no progress with zzp.
                    '97 Grand Prix GT 3800 (sold)
                    Gotta love boost!
                    • TheProfessor
                      • 869
                      now im curious i know that higher ratio affects your not only your lift but also your duration but exactly how does it affect duration
                      I Like V660s
                      Does Chevy make beer
                      ~Jayme~
                      • onefastV6
                        • Sep 2005
                        • 880
                        Mathematically rockers do not change duration however in reality when tested with the proper tools they add a little duration. Normally the duration changes with rocker arms will be very minimal.
                        2000 Grand Am GT
                        2011 Chevy Impala
