ffp 3.1L pully - looking for info
  • treeZ24
    i wanna go fast!
    • Mar 2004
    • 251
    if anyone has one sitting around, would you be so kind as to go measure the back of the pully for me?
    i am looking to see if there is room for 1/8" holes about .120" deep.
    thanks
    Brad
    got zap-straps?
    89 Z24
    13.886 @ 96.16 mph
    street trim - slicks
  • El_Diablo
    STFUniversity
    • 917
    im guessing your trying to lighten the pulley....... but why? to light and you get into harmonics issues without a balanced engine and that can tear it apart, its just one of the things that helps keep those harmonics in check
      • 9190
      Could be for something else...
      I know a couple years back, I was talking to Michael about doing a custom one with holes drilled for magnets to trigger a CPS for a standalone.
      • El_Diablo
        STFUniversity
        • 917
        yeah, that was my other thought, especially with a depth specified
        • treeZ24
          i wanna go fast!
          • Mar 2004
          • 251
          The back edge, or rim, of the pulley is 0.25 inches wide and there is
          approx 0.125 in from the back edge before the first groove for the belt
          rib. It looks to me like there is enough room to mount the magnets. Hope
          this helps.
          Michael | Fast Forward Performance
          - well thats pretty much the same as stock, so its tight but do-able.
          second thoughts... worthwhile to do the work on a slightly smaller UD pully instead of using the stock crank pully? it'd cost me about 150$ (canadian) to get that pully up here by the time its all said and done, where as i could use that money for the machining.
          and yes this is for a standalone cps pickup. it requires 3 magnets each at 120* apart from eachother, just that i'd rather have the pickup on the rear rather then the front, hopefully out of harms way
          got zap-straps?
          89 Z24
          13.886 @ 96.16 mph
          • El_Diablo
            STFUniversity
            • 917
            what system are you using?
            • treeZ24
              i wanna go fast!
              • Mar 2004
              • 251
              SDS em4-f
              its a pretty simple system actually, and had everything that i wanted. most people see the price and what you get, and freak out (well from the guys i've talked to from around here) but the local race / track shop uses it in their 8 hour endurance racing etc. i'm using my own coil packs so that helps out in the cost dept as well. i like it because of its simplicity, no need for a laptop, its got the nitrous retard, many more, and their customer service is amazing.
              i never did get a reply from holley about nitrous jet sizing
              got zap-straps?
              89 Z24
              13.886 @ 96.16 mph
              • eliteweapons
                • Apr 2005
                • 185
                I am looking at the same thing but I am going to try to machine the cuts in the front side of the pulley. If that won't work then we are going to add a trigger wheel on the front. I am checking for a good position to mount the pickup so I can determine the final layout now. I am using an electromotive tec3r. It has a higher resolution crank sensor. Uses 60+2 teeth.
                95 Beretta Z-26
