Who makes forged pistons for the 3400?
  • blackbombshell95
    Kaiō-ken X 10
    • Jun 2004
    • 1386
    My rebuild shop says he can't find any? wtf?
    What companies make custom sized forged pistons for a 3400.
    02 GTP - 90* > Failboat
    www.blackbombshell95.com
  • matt_p
    • Jun 2005
    • 36
    None. There is basically no aftermarket support for the 3400.
    You will have to get custom machined pistons made to spec.
    1991 Cavalier VL Coupe 3400 5 speed
    • tejohnson
      • 359
      I have a quote request into Ross right now. Work through a shop that has a relationship with a company (like Ross, JE, etc.) so you can get a halfway decent break on the cost... ( If they pass it on to you that is )
      Regards,
      Todd E. Johnson
        • 9185
        Uh, that's what he was asking!??! Like Todd said, any piston manufacturer who does custom pistons will do custom pistons for this engine. There are many people out there who have had custom forged pistons made for these engines, so it is entirely possible. It almost sounds like your machinist is looking for an off-the-shelf forged piston, in which case there won't be any. Custom is the only way to go.
        • matt_p
          • Jun 2005
          • 36
          blackbombshell's question implies that he is looking for a company that has some made, sitting on a shelf ready for sale.
          • StudlyCamaro
            • Nov 2003
            • 692
            wiseco made mine
            3.4L camaro some goodies
            • Fiero11
              • Apr 2005
              • 64
              Wiseco made mine also, any CR. Specify rod pin diameter, or better yet send a pin. Piston, rings and pin were $130 each. They will make them to custom rod lengths also.
              • blackbombshell95
                Kaiō-ken X 10
                • Jun 2004
                • 1386
                I said custom. Cause i will be boring my block.
                • StudlyCamaro
                  • Nov 2003
                  • 692
                  mine are .020" over
                  • tejohnson
                    • 359
                    Mine will be .020 over as well, with a lower compression height, thicker rings, and able to accomodate .927 diameter pins with spirolox retainers. If that's not custom, I don't know what is
                    Regards,
                    Todd E. Johnson
                    • TurboZ24
                      • 299
                      Ross made mine, stock bore, 8.0:1 compression, boosted rings spacing, SBC wrist pin, 500 US for a set of 6 with pins with spiral locks.
                      Curtis
                      91\' Turbo Z24
                      http://www.turboz24.com
                      • Fiero11
                        • Apr 2005
                        • 64
                        Again WiseCo. Mine were +.020, .927. 13:1, and with a bridge for 6.0 inch Carillo rods. I have thin rings. I don't know why you want thicker rings.
                        • tejohnson
                          • 359
                          $789 is the total damage.
                          6 Custom 9:1 pistons, zero deck height
                          6 Gas nitrated ring sets at 3.642
                          6 Tapered 4340 .927" pins (SBC)
                          12 Spirolox retainers
                          Regards,
                          Todd E. Johnson
                          • RacerX11
                            • 1060
                            Ouch. Even with a good set of rings $789 is a lot. Mine from Venolia came to $500 for dished, offset pin pistons, tapered pins, and spiralocks.
                            Marty
                            '99 Z-28 - Weekend Driver
                            '84 X-11 - Time and Money Pit
                            Quote of the week:
                            Originally posted by Aaron
                            • El_Diablo
                              STFUniversity
                              • 917
                              when i go to build my engine (im gonna use a 3400 block) i wanna go with an 8:1 c/r, the first ring about 0.250" under the crown (to give the ring land strength to hold up to extreme turbo abuse), gapless rings, taper walled pins and spiral locks
                              a few questions..... is it possible to do that with the ring on our engines? and about how much would you expect that to cost? what price range am i looking at? and also, whats a safe overbore when dealing with high boost levels?
