More fun... :) 12psi coming soon!
  • Doward
    • 127
    Finished file-fitting my rings. No wonder I broke the last set, they were 1/2 of MINIMUM spec, out of the box!!
    Ended up going with .022" on top, and .026" on the bottom
    PermaTorque Severe Duty Head Gaskets:
    ARP Head Studs:
    Now, question is - when I actually tightened down the head studs into the block, do I need to coat them with a little oil?
    3.1L \'88 Camaro - 16G @ 9.5psi
    222/291 @ wheels
    T61 on the way!
  • Guest
    I believe ARP recommends a little bit of oil on the threads, 5w-30 IIRC.
    You may want to clean that deck surface off better, looks like there is still some work needed there.
    • geoffinbc
      Iron Head Enthusiast
      • 5831
      And I hope you put some thread sealer on the studs.
      ARP sells assembly lube. But honestly you can use any assembly lube.
      • tejohnson
        • 359
        Their torque recommendation is different if you are using oil, or thier lube...
        I believe it is 65 ft/lb if you use the ARP molly lube. More with 80 weight oil...
        Regards,
        Todd E. Johnson
        • geoffinbc
          • 5831
          Most assembly lube is moly lube. My GM stuff is.
          • tejohnson
            • 359
            Sure... I was just trying to contrast between moly lube and oil...
            Regards,
            Todd E. Johnson
            • Doward
              • 127
              Yep... slowly coming together... file fit all the rings, and I should have pics of the rotating assembly together, later tonight
              222/291 @ wheels
              T61 on the way!
              • Hybird
                • May 2004
                • 36
                So how do you lube the threads of the stud if you have to seal them as well.. wont you get some kinda chemical reaction and then oil will come out your bolt holes?
                Jordan
