96 lumina 3100, how many lb/hr are the injectors rated for?
  • no_doz
    • Sep 2005
    • 912
    topic-stock injectors?
  • torq455
    If I only had money!!!
    • 1615
    17 lbs/hr.
    Andy
    fastest 1/8: 10.19@ 67.17
    fastest 1/4: 16.16@ 82.70
    • no_doz
      • Sep 2005
      • 912
      thanx man. so what benefits would i get by putting 21 lb/hr injectors in it?
      • Manitcor
        • 573
        nothing unless you tune you PCM to take advtange of them. For a 96 Lumina youll need something like a DHP or HPTuners setup to tune.
        1995 Monte Carlo LS
        3400 SFI 60v6
        • torq455
          • 1615
          The ECM would adjust the rich mixture to the correct 14.7:1 ratio until you go WOT, then it would run too rich and you'd lose power. I put the injectors out of a 3400 which are 19 lbs/hr. It runs great. If you need more gas you can increase the fuel pressure up to a point. You will still need to tune the ECM for that as well.
          Andy
          • no_doz
            • Sep 2005
            • 912
            dumb question but would the dhp tuner possibly allow me to program my computer to function properly with an eaton m90 supercharger as well?
