What does the Stage 1 Cam sound Like
  • john_V63400
    Banned
    • Feb 2006
    • 409
    Im just curious, how much of a diference in sound does the stage 1 Cam from milzy motorsports make a 3400 Grand Am sound. Is it mor Radical or does it just give it a lope.
  • farmerz24
    • Feb 2004
    • 361
    i got the stage 1 boost turbo cam and really couldnt tell the difference.
    • torq455
      If I only had money!!!
      • 1615
      From what I understand, even the stage II&III don't have any kind of a lope. You can ask tejohnson. I'm pretty sure he has the stage III from Milzy.
      Andy
      fastest 1/8: 10.19@ 67.17
      fastest 1/4: 16.16@ 82.70
        • 9191
        Uh.... no. Todd is actually just using a stock replacement cam. He was going to go with a custom grind from CamMotion, but they could do the small lift that he wanted.
        • torq455
          • 1615
          Oops, haha. Wow, I was waaay off! Sorry guys.
          Andy
            • 9191
            And after talking to Todd tonight, he reminded me that Milzy only has 2 different cams. So there is no such thing as a Stage III cam.
            You need to quit sniffing the glue...
            • AaronGTR
              boost lover
              • Jan 2004
              • 708
              Did you order the NA cam? I've seen in your other threads you have the RSM vortech supercharger. The stage1 NA cam wouldn't really be a good cam for you. You'd probably still get some power from it, especially off boost low rpm power, but you'd miss some of the peak power gain because it has more valve over lap than stock which is meant for the NA applications. If you got a stage 1 boost grind you'll be ok. I got one and it has less valve over lap than stock (more lobe seperation).
              Sound wise, it's louder at WOT of course, but I didn't notice a lot of volume increase at idle. The idle is a little rougher, and you do need to increase the idle speed to keep it running right since it has significantly more lift and duration. You also lose some vacuum because of this. It doesn't have a big lopy idle like an NA cam though. That's caused by overlap. I've heard a stage2 NA cam'd car, and the idle is more loppy, but it doesn't sound like a big block camaro or anything. Fuel injected computer controlled cars usually don't run as much overlap as older carburated cars.
              '97 Grand Prix GT 3800 (sold)
              Gotta love boost!
              • xonelith
                • 47
                I'm not 100% sure about the sound of the Stage I, but the Stage II is noticeable, but as Aaron said, not a V8. You can get rid of some of the lope by increasing the idle to say, 950rpm (which is what I did).
                Not for boost
                All Motor 2001 GA GT1
                HPTuners.com
                MilzyMotorsports.com
                GrandsOntario.com
                • JMo60
                  • Oct 2005
                  • 300
                  i got the stage 1 in my 3400, it lopes a little bit, slightly noticable over stock, but not radical
                  94 Grand Prix
