air/fuel gauges what works
  • kprofthestrs
    • Feb 2006
    • 70
    what would be the best a/f gauge to use for my 95 4 wire o2 sensor.
    i guess i'm assuming this isn't a wide band o2 sensor or a digital sensor.
    so would a nice narrow band gauge setup work?
  • tejohnson
    • 359
    Re: air/fuel gauges what works
    IMO, not if want to "trust" it while in open loop.
    Regards,
    Todd E. Johnson
    • kprofthestrs
      • Feb 2006
      • 70
      well no it won't be for "open loop" reading just in general like when i'm running at the track. etc. etc.
      • Syn
        The Master Piece
        • Oct 2005
        • 599
        i'd run a narrow band since a wb is a little pricey, narrow bands tell you if your running rich or lean but not how much of one you are.
        if ur n/a then i wouldn't worry. i ran a nb for 8 mons no prob boosted
        • tejohnson
          • 359
          Which at the track your PCM will be in "open loop" during the entire run...
          Regards,
          Todd E. Johnson
          • Syn
            The Master Piece
            • Oct 2005
            • 599
            QFT!
            • kprofthestrs
              • Feb 2006
              • 70
              so a universal one wire would work just fine then.
              • tejohnson
                • 359
                If you are looking for somethin cheap that is better than nothing, yes. If you are looking for accuracy, no.
                Regards,
                Todd E. Johnson
                • kprofthestrs
                  • Feb 2006
                  • 70
                  what would be a better choice for more accuracy.
                  and instead of having to buy another o2 sensor and a bung. i could just tap my 4 wire o2. couldn't i?
                  • Syn
                    The Master Piece
                    • Oct 2005
                    • 599
                    a heated o2 is better then a non heated for narrow band, to use a nb you have to tap into some o2 sensor lol so the 4 wire would be it.
                    wide bands are the most accurate
                    • kprofthestrs
                      • Feb 2006
                      • 70
                      well not that i was trying to sound idiotic. most of the gauges i've been looking at for the last while all say may work. but also say need o2 sensor kit blah blah blah part# blah blah blah. so as i have always heard better to ask a dumb ? than not ask at all and screw it up.
                      i have and will be dumping a whole lot of cash into this vehicle.
                      since i dumped more than 2200.00 in her last year an just 5 mins ago droped almost another 1000.00. i am only making sure i get what i want the first time out. i know a good bit when it comes cars to repair and maintain. tuning to electrical.pcm and other items i have never dealt with are still fairly new to me so bear with me if you think its a dumb ?. i want it right. and make sure i do it right.
                      • tejohnson
                        • 359
                        I use a PLX (M-250 + gauge) wideband myself ( http://www.plxdevices.com/M-Series_productinfo.htm ). There are quite a few companies, and the costs have come down over the past few years. They are still a tad pricy. The big question is, if you are lean or rich at the track, what would you do to correct the problem? I'm typically not looking at all my gauges at the track besides the critical ones. If the WBO2 goes too lean, I would prefer to trigger an alarm on my laptop.
                        (and no, it does not flash "danger to manifold" shortly before the floorboard falls out...)
                        Regards,
                        Todd E. Johnson
                        • sharkey
                          • Jun 2004
                          • 2061
                          what, you dont want your laptop to do this
                          • kprofthestrs
                            • Feb 2006
                            • 70
                            hopefully with all the items i got will work together to correct and problems of the fuel sort.
                            msd dis-4 ignition w/coils
                            casper elec. adjustable fuel pressure regulator
                            and the new volt,water temp a/f gauges and triple a pod
                            hopefully it won't be big problem
                            well i also just purchased a used laptop and got carbytes so it will datalog & read my pcm since its the 8192 baud and from what i've read its the only program that will read 8192 baud.
                            • Syn
                              The Master Piece
                              • Oct 2005
                              • 599
                              you've dumped 3k into this project? what exactly are you doing? you sound liek your going boost or something
