AFPR
  • StudlyCamaro
    • Nov 2003
    • 692
    AFPR
    any one runnin an adjustable fuel pressure regulatior on a 3x00 motor? where did you get?
    3.4L camaro some goodies
    • 9189
    I am, and I got it from FDP Performance.
    • Canada
      • 84
      Where'd you get that CAI?
      -1996 Beretta
      3400 SFI / 4T60-E
      -1991 Grand Prix SE
      3.4L DOHC / HM-284
      • jweir22
        • 111
        How do you know what pressure to adjust it is there a test to do to see if your getting to much fuel?I think stock is 47 pounds or around there.
        1995 Cutlass Supreme 3100 SFI
        Cold Air K&N Filter
        58mm TB
        Dynomax Duel Exhaust with Performance Catalytic Converter
        FFP Underdrive Crank Pulley
        1/4 mile 15.65 at 90.8 mph
        • StudlyCamaro
          • Nov 2003
          • 692
          wide band O2 on a dyno
          • RacerX11
            • 1060
            Ditto....FDP is the way to go.
            Marty
            '99 Z-28 - Weekend Driver
            '84 X-11 - Time and Money Pit
            Quote of the week:
            Originally posted by Aaron
              • 9189
              CAI is a custom unit from FDP as well. I basically told him the bends I wanted and the amount of couplers I wanted, and he sent it all to me. When I got it, I just cut everything to how I wanted it setup.
              • StudlyCamaro
                • Nov 2003
                • 692
                that sucks , is there anywhere else to get one? thye are closed till march
                do either of you guys remember how much they were?
                • z284pwr
                  • 88
                  You could try the Grand Prix store, they have one from Jensen
                  http://www.pfyc.com/store/merchant.m...y_Code=GPUNDER I'm not sure as all it will fit however
                  Brian Edwards
                  '73 Trans-Am
                  '79 Suburban
                  '90 Beretta INDY
                  '90 Turbo Grand Prix
                  '04 TSX
                  '04 TL
                    • 9189
                    I can call him and see if he's got one handy. I know they are in the middle of moving, so I think that is why they are closed until March. But if he has one he can get to, I'm sure he'd be willing to send it to you. As far as price... I want to say it was around $100, but don't quote me on that!
                      • 9189
                      I talked to Franz this morning and he said he could probably get something together for you. Didn't ask the specifics, but you can either PM him or email him. His name on here is XLR8ING, so you should be able to get an email to him via that. He did mention that he is doing it as a kit now instead of an assembled unit, which might drop the price down some, but also means you'd have to cut your stock FPR to install the adjustable top. Like I said though, get ahold of him and he'll get you the info you need. Just tell him I sent you...
                      • ikessky
                        • 614
                        So is there a proper proceedure for this? Can the average guy do it at home if he has a A/F gauge and maybe some scanning/diagnostics software?
                        • StudlyCamaro
                          • Nov 2003
                          • 692
                          no you need to do it on a dyno, A/F gauges are a joke, they just tell you if you are close to a 14.7 air fule ratio... if your AF nedle moves much ever your car is about to blow or its about to die from too much fuel
                          • v6h.o.
                            • 1418
                            i have a Caspers Electronics afrp. www.casperselectronics.com
                            i picked it up off a guy for payment of doing some work on his car. it was originally installed on a 2.4L fpr. but the 2.4L uses the same FPR, just with the bracket on the wrong side. so i took the stock 3X00 fpr (which is all caspers does as well) and drilled the apropriate holes to mount and use it.
                            cant beat a free AFPR. sorry the pic doesnt really show it very good. only one i have where you can see the unit.
                            Colin
                            • ikessky
                              • 614
                              So scanning software or a digital gauge wouldn't get you anywhere?
