Turbo 3400 Swap!!!!
  • TurboGt
    • Oct 2005
    • 154
    Turbo 3400 Swap!!!!
    I am planing on starting my swap soon. It will be installed in an 87 Fiero GT. I have a turbo, and water to air intercooler off a Typhoon on there way, and plan on getting the engine in the next week or two. As parts start coming in I will post up some pics.
    According to Shaun on RFT the turbo will bolt right onto the factory 3400 down pipe. I plan to mount the turbo where the stock muffler was located.
    I have a few questions:
    Will the stock fuel pressure regulator work and if not where have you guys been getting one that will work from?
    I am looking at getting a SPEC stage 3 clutch, is this the right one for my application? Will the throwout bearing the kit comes with work or will I need to get a different one?
    As I come accross more questions I will let you guy know
    Thanks for your help
    Marq
    Mega Squirted Fiero
    How I did it here
  • sharkey
    • Jun 2004
    • 2061
    what tranny are you going to be using??? the 90-92 getrag has a different sized release bearing.
    if you are using the fiero tranny, get a neutral balanced flywheel (88+) or knock the weight off of your stock flywheel. then just use any clutch for a fiero.
    • AaronGTR
      boost lover
      • Jan 2004
      • 708
      The 3400 stock FPR won't read boost correctly so you'll need to replace that. Caspers makes an adjustable FPR with a 1:1 rising rate that will read boost. You can get it at partsforyourcar.com and a few other places.
      '97 Grand Prix GT 3800 (sold)
      Gotta love boost!
      • TurboGt
        • Oct 2005
        • 154
        Sharkey I am planing on getting a new flywheel, and yes I will be using the stock fiero 5 speed getrag trans.
        AaronGTR thanks for the link.
        Mega Squirted Fiero
        How I did it here
        • MidnightriderZ24
          • Jan 2005
          • 699
          ive actually jsut finished my turbo setup on my 3400 in my cavalier. first off man, your in for a treat lol. i used a tgp chip with the 22lb injectors and a cartech RRFPR. it runs alright right now, but i need to tinker with it yet... :P
          [SIGPIC]
          12.268@117... 11's to come!
          • TurboGt
            • Oct 2005
            • 154
            Do you have a link to your build?
            What size are the stock 3400 injectors? This will be my weak link untill I upgrade.
            I will be running my Mega Squirt and a wide ban so I hope to have it running strong.
            Are you part of the v6z24 forum? I tried to join and they wont approve me.
            Mega Squirted Fiero
            How I did it here
            • Manitcor
              • 573
              either of you guys have any links to the RRFPRs. I tried PFYC and had no luck finding them there. I was just going to use an adjustable FPR like this one
              perhaps im just confused.
              1995 Monte Carlo LS
              3400 SFI 60v6
              • TurboGt
                • Oct 2005
                • 154
                This is the one I found form the link Aaron gave me. I dont know if it has the 1:1 rise rate though.
                Shop performance car parts online at PFYC.com! Explore aftermarket & OEM parts like camshafts, spoilers, turbos & more — shop now!
                And this is the one I found: Cost $250
                I would like to know if the one from pfyc will work because it is almost $100 cheeper.
                Mega Squirted Fiero
                How I did it here
                • MidnightriderZ24
                  • Jan 2005
                  • 699
                  link is http://www.v6z24.com/jbodyforum/viewtopic.php?t=75285
                  its about 30 pages long thread and still growing. :P
                  [SIGPIC]
                  • AaronGTR
                    boost lover
                    • Jan 2004
                    • 708
                    That's the same one that pfyc carries. They just give you the option to get the regulator only without the gauge and stuff which is why it's $40 cheaper, or you can get it with the kit for the same price. That regulator will work with boost. It's a straight 1:1 ratio though (which I prefer), not a rising rate like a vortech FMU at 5:1 or anything.
                    TurboGT, injectors from a 2000+ 3400 are from delphi and rated at 22.5lb/hr at 55psi. '99 and earlier 3400's had 19lb/hr bosch injectors.
                    Gotta love boost!
                    • Berettaspeed
                      • Apr 2004
                      • 109
                      i would go with at the least 36# injectors.
                      89 BerettaGT 3400 5spd
                      60' 2.106 street tires
                      Best ET 14.313@95.37 N/A
                      Now Boosted
                      14s@109 (poor tune still rich, poor driving skills, poor owner)
                      • TurboGt
                        • Oct 2005
                        • 154
                        I got some 33's for dirt cheep so they will have to do for a while
                        Mega Squirted Fiero
                        How I did it here
                        • TurboGt
                          • Oct 2005
                          • 154
                          Sorry I havnt had to much time to update. Here is some of the stuff I have so far:
                          Water to air upper and lower intercooler and high flow pump
                          Spec stage 3 clutch
                          innovative wide ban O2
                          Walbor 255 l/hr fuel pump
                          TD06 18G turbo (just finished rebuilding)
                          33lb injectors
                          3400 w/ 45K miles
                          I did some porting work on the Turbo and almost have the flange done
                          Mega Squirted Fiero
                          How I did it here
