Any guesses what the 3900 would make hp wise without the VVT and Vintake working? What does CAN stand for?
3500 Top End Swap Complete
CAN is also more advanced engine diagnostics, came out in '02 I believe.
My scanner was good to '03 and some of the '03 cars were already can2 from what I wqas told, and I think CAN3 came out in '04.
What does CAN mean?
GM CAN add more crap, they CAN charge you more for less, and it CAN be another reason why mechanics really don't make crap for money because they are always buying more tools to stay current, so GM CAN bang your wallet and CAN bang your ass.sigpicHow to make High performance Emissions:
CAN = Controller Area Network. It just describes how the new generation of GM ECU's communicate. Much like the change from OBD to OBD2, the new stuff is more advanced, and the current crop of OBD2 tuners and tools won't work with the CAN ECU's.'99 Z-28 - Weekend Driver
'84 X-11 - Time and Money Pit
Quote of the week:Originally posted by AaronThis is why I don't build crappy headers. I'm not sure, I don't know too much about welding.
Any details on the map sensor? I have one off of a 3500, and I pulled the pig tail off of a 98+ Crapalier with a 2200, however it doesnt have the plug end that yours does.
Thanks,
Craig
Right, you'll have to splice wires. He got the plug end from something so he made his an adapter to plug into his old style map connector.sigpic
yeah, I ended up soldering mine on any way.2000 Grand Am GT
2011 Chevy Impala
I was always under the impression GM's implementation was actually SWCAN (Single Wire Controlller Area Network), but I have not researched for about 2-3 years now. CAN, SWCAN, IDB-1394, MOST.... It is hard to keep up these days.
I have a new MAP sensor, and the 3 plug Map wire from the J-body, where did you find the adapter plug that goes from the Crapalier into the stock N body harness?Originally posted by onefastV6yeah, I ended up soldering mine on any way.
Thanks,
Craig
I just can't understand why more people aren't doing this swap!! its cheap, sounds fairly easy, and seems to add a decent amount of horsepower! i've pretty much killed my dreams of superchargers to do this to my grand am. (i would love to see what a supercharged 3500 could do though...) =)
so whats the actual gain for the swap?? i am finishing up mine now... never seen any numbers on it...1996 beretta w/a 04' 3400 3.5 top end, 42.5lb hr, 180*thermo, t3t4 .63ar 60 trim, LC1 WB, FMIC, greddy rs BOV,TIAL 38mm wastegate,791xv,fidanza,stage III clutch,TG LSD,ffp udp,walbro 255 lph,strut tower brace,22 rear sway,30 front sway,92 5sp tranny,92 subframes,all solid mounts,kyb shocks and struts,eibachs,battery in trunk,tgp map sensor,DHP Powrtuner,euro front and rear and more to come soon...mods sitting in boxes waiting install....zo4 kit,GTU wing,and more..
I haven't made it back to the dyno since I completed the swap due to KR issues. I am hoping that DHP fixing the VE table issues will help, along with filling my tranny mount with urethane will correct some of the KR problems.Originally posted by rickykline View Postso whats the actual gain for the swap?? i am finishing up mine now... never seen any numbers on it...
Before I put down 143.2 HP with only a Borla catback, so only time will tell.2000 Grand Am GT
2011 Chevy Impala
my best stock dyno run was 156.4 hp and 190tq with 128* and 95% hum. that was along time ago1996 beretta w/a 04' 3400 3.5 top end, 42.5lb hr, 180*thermo, t3t4 .63ar 60 trim, LC1 WB, FMIC, greddy rs BOV,TIAL 38mm wastegate,791xv,fidanza,stage III clutch,TG LSD,ffp udp,walbro 255 lph,strut tower brace,22 rear sway,30 front sway,92 5sp tranny,92 subframes,all solid mounts,kyb shocks and struts,eibachs,battery in trunk,tgp map sensor,DHP Powrtuner,euro front and rear and more to come soon...mods sitting in boxes waiting install....zo4 kit,GTU wing,and more..
