How to tell if heads have been shaved
  • Will'sFiero
    Too many valves
    • 276
    How do I tell if a set of iron heads has been shaved?
    On SBC's, the thickness of the bosses for the lower head bolts can be measured and compared to stock. Is there a similar tell-tale on the V6 iron heads? What should the measurement be?
    Current:
    \'87 Fiero GT: 12.86@106 - too dam many valves; ran 12.94 @ 112 on new engine, then broke a CV joint
    \'88 Fiero Formula: slow and attention getting; LZ8 followed by LLT power forthcoming
    \'88 BMW 325iX: The penultimate driving machine awaiting a heart transplant
    Gone, mostly forgotten:
    \'90 Pontiac 6000 SE AWD: slow but invisible
  • billy wood
    • 10
    I would CC them with a piece of thick plastic window material with a tiny hole in it & a syringe. Just use a bit of vasoline on the valve edges & the plastic plate. I use the 90% rubbing alcohol in the syringe.
    • moonwell
      V6Z24
      • Feb 2006
      • 53
      Most shops should stamp them somewhere on the surface with the amount they have been shaved.
      V6Z24.com
        x2
        • StudlyCamaro
          • Nov 2003
          • 692
          however if the heads were part of a large batch that was intended for a racing team its possible that they might not have bothered stamping them
          just a thought
          3.4L camaro some goodies
          • jp_grasshopper_007
            Power Level:1,000,000
            • Mar 2006
            • 120
            why do you want to know if they've been shaved?
            are they warped from getting hot and you think they're already to thin?
            because I\'m not Canadian
