Fuel Injectors?
  • MrGoodwrench
    • Jun 2006
    • 6
    Fuel Injectors?
    Hi Guys
    I just want to know what kind of fuel injectors should I run in my 2002 3400 motor because I want to push anywhere from 300 to 350hp with a turbo and I need to know what kind of fuel injectors I need.
  • tejohnson
    • 359
    How much boost? 12-13 PSI?
    Regards,
    Todd E. Johnson
    • Syn
      The Master Piece
      • Oct 2005
      • 599
      he wouldn't need but 10psi if done right
      its ben proven already
      they'll be diff depending on your setup, you going RRFPR?
      • tejohnson
        • 359
        On a stock bottom end?
        And with a 2002, I would stay away from a rising rate. Just go with boost referenced. The *.1 RR FPR's are for those that can't tune... Like Dodge neons... lol
        Regards,
        Todd E. Johnson
        • torq455
          If I only had money!!!
          • 1615
          ballpark? thinking #24 or little bigger depending on boost and fuel pressure. my dad with 6 psi boosted an 87 350TPI with about 380 at the wheels, he used #26 with 54 fuel psi. proally best to get somewhere in the middle. then you can either tune the computer, adjust the fuel psi, or both to fine tune. 350 hp on a stock bottom i believe is fine, although pushing it a little. any more than that, use SBC rods and mill to fit the journals. be sure to install arp rod bolts. the 660 store sells em.
          Andy
          fastest 1/8: 10.19@ 67.17
          fastest 1/4: 16.16@ 82.70
          • timg
            • Feb 2004
            • 718
            24 lb/hr injectors probably won't get you 300+ whp. Think more like 36 lb/hr or 42.5 lb/hr injectors for 300+ whp.
            Tim
            325 whp 350 lb-ft
            • MrGoodwrench
              • Jun 2006
              • 6
              i probley will run about 10 to 12psi of boost
              • Syn
                The Master Piece
                • Oct 2005
                • 599
                yeah but how will you run it, bigger injectors pump and custom tuning or what?
                my friend is running 32lbers , but i know of people with a rrfpr running 22lbers
                also yes tejohnson, it was dynoed and everyhting a cavalier
                on v6z24.com 89Jyturbo
                heres his site http://www.khturbo.net/
                hit iroc is amazing
                • torq455
                  • 1615
                  Tim
                  Uhhhh, well, it did. remember he didn't use stock fuel psi or stock fuel pump.
                  Andy
                  • tejohnson
                    • 359
                    It is a good idea to change out the fuel pump, and I would say 42.5# injectors... Anything less, you'll see some high IPW's (from what I have seen). Using a RR FPR would work, since it has for some, but good luck on getting the fueling right...
                    Regards,
                    Todd E. Johnson
                    • AaronGTR
                      boost lover
                      • Jan 2004
                      • 708
                      He didn't say wether he was shooting for 300hp at the crank or the wheels. Thats an important destinction. If it's crank, I'd say 28lb injectors would do it. I was already there on stock injectors albiet pretty much maxed out. 300+ at the wheels, I'd definitely say 36lb or 42lb injectors. He can definitely do it on 10-12psi with proper tuning and a good intercooler. He's gonna need tranny work next though.
                      '97 Grand Prix GT 3800 (sold)
                      Gotta love boost!
                      • MrGoodwrench
                        • Jun 2006
                        • 6
                        well if i go with 12 psi i probley will get 350 at the wheels and probley 300 at the crank and ya im going to use a 5sp 282 tranny
                        • timg
                          • Feb 2004
                          • 718
                          The point is, that was a V8. He can run smaller injectors and make more hrosepower. His 24 lb/hr injectors are equivalent to a 6 cylinder with 36 lb/hr injectors. I wasn't trying to say that your dad didn't do that, I was just trying to say that 6 cylinder engines and 8 cylinder engines need different sized injectors for the same horsepower.
                          RR FPR's should let you get close to 300 whp with a Walbro pump on stock injectors. They will make it quite difficult to tune correctly though. A RR FPR will get you 90% there for low boost, but be very careful of high boost (10 psi +) with a RR FPR (FMU). Mine crapped out around 9 psi and forced me to upgrade to 42.5 lb/hr injectors to run over 9 psi.
                          Tim
                          325 whp 350 lb-ft
                          • torq455
                            • 1615
                            ohhhh yeahhh, forgot about the power vs. #of cylinders = certian size injectors. me bad
                            Andy
                            • MrGoodwrench
                              • Jun 2006
                              • 6
                              well can i use the ford green tops? if i cant is accel any good?
