i am on a diff computer so i just linked my first post
my first data log!
i'm confuised as to why there is KR, and why the integrater is changing, the engine temp is cold (open loop) so the ecm dosen't read the 02. integrater i thought should be at 128 until closed loop. code 43 i knock sensor. looks like it's taking all the timing out. thinking that's why it's not wanting to run.Andy
fastest 1/8: 10.19@ 67.17
fastest 1/4: 16.16@ 82.70
indeed the knock sensor took a shit and i am way too rich so i guess its back to stock injectors again and a new knock sensor
then a new log.
maken progress tho
stock injectors don't keep up with gen3 top end, and especially not with your cam. So you need them big injectors, but you need that updated code burned to a chip so it don't flood. I'd start with the knock sensor first.
Or you could go with 94-(99?) 3100 injectors as they are I think like 1-2lbs less or so than 19lbs. There's some year range there where it would be inbetween. who knows might end up being perfect w/o tuning if you're lucky, lol.sigpic
3100's are 17lbs so i'll keep the 19's cause out of limp mode the car shouldn't have a prob as 89j is running 19lb injectors no probsigpic
i got 2 knock sensors both from small port 3100's but i guess those won't work
WTF!
but all thats left is a o2 sensorsigpic
