Fuel Pump Upgrade?
  • Identity Crisis
    Lost at Birth
    • Jul 2006
    • 295
    Fuel Pump Upgrade?
    I want to add a fuel pump upgrade to V6/60 while I am going boosted and N20.
    What are your opinions on this pump from MSD?
    I am looking at the numbers and I dont think it will be good enough. Or maybe I am just trying for overkill.
    Tell me what you think. Even give me a few suggestions.
    I dont know what this means but "ASS HATS" is funny
  • tejohnson
    • 359
    Maybe if you are going with a fuel cell. Otherwise, you have an in-tank pump, correct?
    Regards,
    Todd E. Johnson
    • prophiseer
      Blaspheming Heretic
      • Jun 2006
      • 354
      I bet ya do
      As far as in-tank pumps go, this is your best bet:
      in-tank pump
      she requires a little bit of wire swapping and splicing, but works great. Installation in the OBDII pump assembly vehicles is a bit tricky, but it can be done with some careful work. Price ain't all that bad compared to other internal / external pumps on the market, either.
      pump flow is rated 67gph with max psi rating of 90.
      this pump is a direct replacement for anyone with a late 80's early 90's F-body, too - harness and all
      N-body enthusiast:
      {'87 Grand Am SE - 3.0 90* v6} / {'93 Grand Am LE - 3.3 90* v6}
      {'98 Grand Am SE - 2.4 Q4} / {'99 Grand Am GT1 - 3400 60* v6}
      Current Project:
      {'90 Chevrolet C1500 Sport 350TBI}
      • tejohnson
        • 359
        Depending on the vehicle you have, it may have a line coming off the pump to a venturi pump in the bottom of the fuel assembly. If you don't supply that line with pressure, you will have issues. I think I remember you had a 3100, but I can't for the life of me remember what vehicle you have...
        Regards,
        Todd E. Johnson
        • Identity Crisis
          Lost at Birth
          • Jul 2006
          • 295
          My car is a cavalier.
          engine is being built.
          3.1L Block
          3400 heads
          3.5L Intake
          4.3L TB
          hypereutectic .40 over Pistons
          hayes rings and Bearings
          High Vol/Pres Oil Pump
          CraneCam 272
          Comp Cams LS6 Valve Springs
          Comp Cams Roller Rockers 1.6 Ratio
          Comp Lifters
          Comp Cams retainers and locks
          MSD DIS-4
          MSD DIS Interface Blocks
          MSD Coils
          MSD Wires
          NGK Iridium Plugs 2 ranges colder
          19# Accel Injectors
          T4 Garret Turbo
          Venom N20 System 125HP w/
          Heater, Blow Down Tube, remote Opener
          I hope this gives you an idea of what I have in mind. So you can see I need more FUEL.
          • AaronGTR
            boost lover
            • Jan 2004
            • 708
            The walbro intake pump is also a good choice. Flows 255lph (or 67gph so about the same).
            '97 Grand Prix GT 3800 (sold)
            Gotta love boost!
            • tejohnson
              • 359
              3.1L Block
              3400 heads
              3.5L Intake
              4.3L TB
              CraneCam 272
              Comp Lifters
              MSD DIS-4
              MSD Coils
              MSD Wires
              19# Accel Injectors
              T4 Garret Turbo
              That's cool, but not why I asked... lol I want to know what exact body style and year of the car for more info on the gas tank and fuel pump assembly
              Because.... If the pump assembly has a venturi, then you should get the 3800 specific walbro kit from ZZP, otherwise, any other in-tank pump with 12ga line will work
              Regards,
              Todd E. Johnson
              • Identity Crisis
                Lost at Birth
                • Jul 2006
                • 295
                I have two tanks.
                A 1992 and A 1994
                • tejohnson
                  • 359
                  D'oh! Too old for my service manual. Have you pulled the fuel addambly outta them yet? If so, is there a plastic line going from the pump to the bottom of the assembly?
                  Regards,
                  Todd E. Johnson
                  • Identity Crisis
                    Lost at Birth
                    • Jul 2006
                    • 295
                    Nope have yet to pull the sending units.
                    I will do it this week.
                    • 3.5MGB
                      • Sep 2007
                      • 19
                      Feul pump upgrade, no stock unit, fuel cell usage
                      I'm looking for suggestions for my 3.5l that will be SC in the next year or two. My car will have a fuel cell so we are talking an external fuel pump. Will the one listed earlier in the thread be a good one to begin looking at?
                      Any other suggestions?
                      in build, Stage 1
                      1976 MGB - 3.5l (2004 Malibu), GM V8 T5, 3.9 gear
                      FAST ecm
                      • sharkey
                        • Jun 2004
                        • 2061
                        the msd pump is a decent choice. its also not that much money and would be enough fuel pump for what your building. here are a couple more options
                        http://www.jegs.com/webapp/wcs/store...50906_-1_10307
                        http://www.jegs.com/webapp/wcs/store...55251_-1_10307
                        http://www.jegs.com/webapp/wcs/store...47713_-1_10307 - comp 110fi
                        http://www.jegs.com/webapp/wcs/store...50555_-1_10307
                        • zofo61
                          Banned
                          • Oct 2005
                          • 436
                          Todd.....did you ever get that monster running ?....your GroomLake photos hvnt been updated in a while.
