My engine is currently 50 miles away, so I can't measure it myself this weekend. Does anyone know or can measure the lifter bore spread on a RWD Gen 1 from centerline to centerline from intake to exhaust? I'm trying to get some hydraulic roller lifters custom made, and that's all the info left I need.
Need a lifter measurement
1991 GMC Syclone #449 - Stock
1988 Pontiac Fiero GT - 3.4L HT GM crate engine
2002 Yamaha V-Max - It go fastTags: None
How much precision do you need?
I might be able to get that information for you shortly.60v6's original Jon M.
As accurate as your able to get. I would like to get it to the nearest 100th of an inch.1991 GMC Syclone #449 - Stock
prolly wanna try 1000 of an inch, if ur off by 1-1000 of an inch ur screwd trust me!! You will need the lifters to be 1 or 1-1/2 1000 of an inch smaller than the bore for clearnce kuss of the oil..Last edited by Ortie666; 08-26-2006, 03:23 AM.VIDEO Acadian http://videos.streetfire.net/video/8...7f00197eea.htm
Six-t-Six Motorsports
2.8L Chevette Roadcar
3.2L Acadian Racecar
I'm not talking about the bore diameter. Just the distance between the two bores from center line to center line. It shouldn't have to be exact, since the link bars will have to be slotted to allow the size of the distance between the two link bar hinges changes as one raises and the other remains in on the base circle. Mainly I just trying to get the proper link rod length.1991 GMC Syclone #449 - Stock
Nevermind. Apparently I'll be heading over there this weekend anyway. So I'll be able to measure it myself. Thanks anyway!1991 GMC Syclone #449 - Stock
