3900 Info
  • Kenova
    • Nov 2011
    • 16
    #181
    Did the engine in post #175 make it to the dyno?
    I'm curious as to how well it did.
    Ken
    • ericjon262
      build it.
      • Jan 2010
      • 2218
      #182
      Ken
      • CNCguy
        Bisong eater :P
        • 1017
        #183
        Regretfully, no. Ran out of time and money and needed to get the MG running. I do plan to dyno it whenever I get around to finishing the tune. I will be disappointed if it doesn't hit at least 225whp. At the moment the car is sitting with a busted rearend.
        MinusOne - 3100 - 4T60E
        '79 MGB - LZ9 - T5
        http://www.tcemotorsports.com
        • socorob
          • Mar 2012
          • 12
          #184
          I've been following this thread for a while now. I'm very interested how it turned out because I'm thinking of putting the same engine in a sunbeam. With your shortened timing cover, what's the length x width x height of this engine? Sorry if I'm posting in the wrong place. Thanks.
          Robbie
          • ericjon262
            build it.
            • Jan 2010
            • 2218
            #185
            Robbie
            is that another vote for stickie?
            • Guest
              #186
              Another update for those following this. I got out my digital indicator, made a degree wheel and checked the valve events with the actuator in the default position (total advance). I plan to do some more measurements as something seems very strange to me. I checked all the numbers 3 times each and got consistent readings.
              The valve timing checked at .050 lift is as follows:
              Intake Open: 1 ATDC
              Intake Close: 30 ABDC
              Intake Duration: 209
              Exhaust Open: 59 BBDC
              Exhaust Close: 29 BTDC
              Exhaust Duration: 210
              The duration looks pretty good but what seems strange to me is what is what I calculate the LSA at. By comparing the opening positions of the valves, the LSA calculates to 120 degrees. I know that it isn't the most acurate way to do it but using the Crane Cam spec cards, the numbers usually come out within a degree or two. I did not seen any cams with this much LSA on Cranes site.
              I am going to try another method of measuring that I found and see if it comes out differently. It seems as though this would create an issue when it comes to regrinding the cam. Thoughts?
              Ressurecting really old thread. I just did some measurements from a 2009 3.9 LGD engine. This differs from an lz9 as it was designed for flex fuel if wanted. This might make a difference in cam specs but not sure.
              I also checked measurements with cam in default advanced position.
              Measurements were made on the lifter body not the plunger.
              Duration at .050.
              Int 194
              Exh 195
              Lift
              Int .272
              Exh .286
              Cam events @ .050
              Int opens 12 ATDC
              Int closes 26 ABDC
              Intake Centerline checked in at 123
              Exh opens 38 BBDC
              Exh closes 23 BTDC
              A genius it does not take to see this is a peanut for a cam. Gm did lower the HP output I believe of this engine in the later years by like 8 hp or so, which could be because of the cam?
              • Guest
                #187
                What's the separation between I and E?
                • Guest
                  #188
                  Exh centerline is right around 116.5 so LSA should be right about 119ish or so on my cam. CNC measured 120 or so, so I think my measurement is about right if GM kept things the same.
                  • Guest
                    #189
                    That's pretty wide. Makes a strong argument for the cam to be constantly adjusted between advanced and retarded as the engine is running and not just changed as the RPM changes.
                    • Guest
                      #190
                      it is wide but if you have looked at the cams coming from GM factory lately, the majority of LS cams have wide LSAs The zr1, zl1, L99, ls9 for example. Even the ls1, 2 and 3 are all over 115 lsa
                      Prob has something to do with emissions and a smooth idle.
                      Cam swaps on a 5.3
                      This dyno might read a smidge high, but the gains are real. 5.3 is close to displacement per cylinder as well as hp per cylinder as the 3.9. The 5.3 stock heads flow just a smidge less than the 3.9 heads.
                      If you look at that link, gains of 100 hp from a cam swap is possible. Break it down to additional hp per cylinder, and you can see that the 3.9 should be able to theoretically make about 310-330 crank hp with a great tune, with just a cam swap. Realistically its prob closer to 290-300 cam only
                      Joshua R on this board made 238 whp with a small cam swap, 75mm tb and headers through an auto trans. His cam only had 214 duration on the exhaust. With 15% drivetrain loss thats about 280 crank and with an 18% loss its about 290 crank hp.
                      huge potential with this engine.
                      • mbirt
                        • Nov 2016
                        • 7
                        #191
                        Originally posted by bigcheese View Post
                        Cam swaps on a 5.3
                        http://www.hotrod.com/how-to/engine/...st-comparison/
                        This is exactly what I've spent the last several months thinking about--squeezing LS "cam only" gains out of the LZ9 which, on paper, looks like a 3/4 LS engine. I want to build this theoretical 315 hp "cam only" 3.9, pair it to an F23, put it in my 1986 MR2, and compete at the GRM $2017 challenge.
                        I have GM's SAE paper on the development of the LS1 ASA racing engine in front of me. The LS1 in this configuration made 430-450 hp and I see it as clear recipe for achieving 300-315 3900 here:
                        A custom (no VVT) 60v6 cam similar to the following:
                        226/236 int/exh @ 0.05" lift, 0.525" / 0.525" lift, 110 LSA
                        LS3 valve springs with requisite increases in install height (eliminate spring base cup and use PAC +.050" locks)
                        1.75 for 11" stepped to 1.875 for 25" primary long tube headers
                        ~10.5" intake runner length to match the LS intakes and no UIM restriction (I'm looking at you, LZ9 ramhorn)
                        I have a plan to increase compression ratio (to 10.8:1) and avoid longer pushrods with a reduction in cam base circle, but I'm not going to suggest that everyone removes the center shim of their head gaskets.
                        LZ9 Head
                        Chamber volume: 36cc
                        Lift_________[0.100]_[0.200]_[0.300]_[0.400]_[0.500]_[0.600]_
                        stock(int)____62.4___128.6___186.8__218.9__232.1__ 238.5_
                        stock(exh)____52.6___100.0__138.2__150.1__154.7__1 55.8_
                        Intake Valve Diameter: 1.87"
                        Exhaust Valve Diameter: 1.52"
                        LM7 5.3 Head
                        Chamber 61.15 cc 0.100 0.200 0.300 0.400 0.500 0.550 0.600
                        Intake 200 cc 63 128 179 210 218 221 226
                        Exhaust 70 cc 54 93 121 145 163 168 174
                        Valve Diameter Intake 1.89"
                        Valve Diameter Exhaust 1.55"
                        LS1 Head
                        Chamber 66.67 cc 0.100 0.200 0.300 0.400 0.500 0.550 0.600
                        Intake 200 cc 67 122 178 215 219 223 227
                        Exhaust 70 cc 52 97 133 156 170 176 180
                        Valve Diameter Intake 2.00"
                        Things working for the 3900:
                        -Forged crank and generally more oversquare than LS engines
                        -Shorter valves and pushrods for reduced valvetrain mass (6400 rpm stock fuel shutoff, LS3/525 crate engine has 6600 limiter, so 7000 rpm rev limiter may be possible in LZ4/LZ9 with LS3 springs)
                        -Better intake port flow than 5.3 and LS1
                        -Even firing order per bank for better exhaust collector scavenging effect
                        -Even firing order per bank impact on intake plenum design
                        -Low cost, light weight, GM Metric bellhousing pattern
                        Things working against the 3900:
                        -The lower intake manifold is an unknown to me as a 60v6 outsider and it's the only thing I feel like I don't (cheaply) have control over in this build
                        -The assembled camshaft being difficult to convince shops to do a regrind--anyone know any cam grinders friendly to hollow camshafts?
                        -"Mist quench"... With such a small combustion chamber and a common piston design with the 3500, GM had to put the 3900 piston .044" down the hole at TDC, or .097" piston to head including the .053 head gasket
                        -The cylinder offset with each bank in a different thrust direction. Do I need to care about this for anything other than piston design?
                        I think the good outweighs the bad and I think I'll make close to 300 whp with less than $500 in the engine build. What am I missing here?
                        • 34blazer
                          • Sep 2007
                          • 341
                          #192
                          Ive measured the OEM headgasket at .065" from my LZ9, since its already been installed and run for 24K miles, Im thinking that it should be compressed right around .060'?. Also been looking at piston/rod combos and was looking at the wiseco LS1 k449x3903 piston. With a 6.125" rod and the wiseco piston CH of 1.050", the piston will be proud of the deck at least .015" depending on if the block needs to be squared up. The quench will be right around .045".
                          Im not sure why the piston sits down in the bore that far, I measured about .040" as well. Whats the reason for so much piston-to-head clearance?
                          '86 Grand National
                          • mbirt
                            • Nov 2016
                            • 7
                            #193
                            The piston sits so far down the hole in the LZ9 because it shares a common compression ratio, piston, cylinder head, and head gasket with the LZ4 despite the increased stroke. The extra TDC volume to maintain a constant compression ratio despite increased displacement thus comes from the connecting rod that GM had to change for the stroke change anyway--good thinking for minimizing part numbers on the part of GM bean counters. They publicly justified the huge piston to head clearance as something called "mist quench", but the only real engine engineering justification I see for it is reduction in crevice volume (quench area) for a reduction in unburned hydrocarbon emissions. But the real reason is to keep as many parts common between the two engines as possible.
                            I don't doubt that you measured your HG at .065", but .053" is the HG thickness I settled on after reading other threads like this one and a post by a Scoggin Dickey employee in one of them that voted for either .052 or .053. Here are my CR calculations for the two engines. A stock flat top LS1 piston with a 1.330" compression height will put the CR at 14.5:1 in an LZ9.
                            All units mm LZ4 LZ9
                            Bore 99 99 (GM)
                            Stroke 76.0 84 (GM)
                            Comp height 32.89 32.89 (Silvolite)
                            Piston dish cc 18 18 (Silvolite)
                            Block deck height 224 224 (GM)
                            Rod length 153 148 (Pauter LZ9)
                            Down the hole 0.107 1.11 calc
                            Head gasket 1.3462 1.3462 .053(forum avg)
                            Quench height 1.453 2.45 calc
                            Chamber CC 36 36 forum avg
                            TDC vol CC 65.19 72.88 calc
                            Disp CC 585.03 646.61 calc
                            CR 9.97 9.87 calc
