Installed LS6/LS2 valve springs on '01+ 3400
  • Syn
    The Master Piece
    • Oct 2005
    • 599
    02 is when the guide diameter chaned so thats where the 2.2 seals come into play
    i have 00 heads and the 3.1 seals worked fine
    • AaronGTR
      boost lover
      • Jan 2004
      • 708
      Not according to everyone else they weren't. I've seen a lot of people on here and over at grandamgt.com with late year '00 or '01 heads that had to either grind the ls1shims because they wouldn't fit over the guides, or go with the chrysler shims and valve seals that were found to fit. Here's a thread. http://60degreev6.com/showthread.php...ht=spring+swap On my particular 2000 heads they fit just fine, but my car was made in like march of '00 and the engine was probably assembled in '99 so it had the old diameter.
      '97 Grand Prix GT 3800 (sold)
      Gotta love boost!
      • Syn
        The Master Piece
        • Oct 2005
        • 599
        i had to grind my ls1 shims as well and from where i read that was said it had to be done anyways.
        but either way good info
        • prophiseer
          Blaspheming Heretic
          • Jun 2006
          • 354
          (not sure if this has been covered, but . . .) I'd like to point out that the difference isn't limited to the 3400 motors, either. The spare '00 heads that I have came off a 3100 Malibu, same exact part number and casting as the '99 3400 heads, but the valve guide is larger. Not sure of when the motor was assembled, though, as I never had access to the car. But 100% certain the motor is a 2000 model.
          N-body enthusiast:
          {'87 Grand Am SE - 3.0 90* v6} / {'93 Grand Am LE - 3.3 90* v6}
          {'98 Grand Am SE - 2.4 Q4} / {'99 Grand Am GT1 - 3400 60* v6}
          Current Project:
          {'90 Chevrolet C1500 Sport 350TBI}
          • Rhedalert
            Dr. Feelgood
            • 1574
            Originally posted by project90tempest View Post
            Did they need any modification? Because I think I had read somewhere on another forum that pre-2000 would use the 3.1 seals.
            I just wanted to make sure and hear everyone's insight. Anyone know a part# for the 3.1 seals?
            nope, not at all. I'll also add to the mix that my '01 3400 has the larger valve guides.
            Brian
            3400 SFI V6, 4T60e
            • project90tempest
              • Jul 2005
              • 19
              #21
              Awesome link!
              Thanks. I ordered the LS6 springs and hopefully today I can get the LS1 shims and the 3.1L seals.
              1990 Chevrolet Beretta GT *new project*
              1990 Pontiac Tempest LE *GONE* ~formally 3400/5-speed equipped~
              • AaronGTR
                boost lover
                • Jan 2004
                • 708
                #22
                Also good to know. Good info. So they probably changed all the valve guides in both motors around the same time.
                Gotta love boost!
                  Where can you get the toyota land cruiser spring seats??
                  My uncles shop made it sound like they couldn't get them. And a local machine shop said they come with the springs..
                  • project90tempest
                    • Jul 2005
                    • 19
                    #24
                    I'm guessing you'd have to go to the dealership.
                    On that topic, what other/newer cars came with 3.1s that I can use their valve stem seals? I asked the GM dealership for a set for a '90 3.1L and they said they were discontinued.
                      up to 93 had the 3.1
                      Go to an autoparts store for the seals, Fel-Pro should have a set for that.
                      I got my seats from a Toyota dealer, so yeah you were right on that. He said I ordered the last 13 in the US... hehe
                      • gectek
                        I Hate Nose Hair
                        • Aug 2006
                        • 1472
                        #26
                        ok so if i were doing this replacement for my 02gagt 3400 i would use the 2.2l seals, the ls1 shims, and ls6 springs? should i notice less vavle float at higher rpm with this upgrade?
                          your probably not reaching any valve float right now, but for the 02 heads you may be the different valve guides, same as the 3.1's.. I'm not sure on that one.
                          • Syn
                            The Master Piece
                            • Oct 2005
                            • 599
                            #28
                            comp cams has seats where you don't have to grind them to fit over the guides. i had to grind my ls1 shims
                            • gectek
                              I Hate Nose Hair
                              • Aug 2006
                              • 1472
                              #29
                              well i have a dhp 1.0 pcm and it likes to pull in the upper rpms til it shifts from 1-2 6300 2-3 6k and i am getting alot of revs and no power. im actually losing foreward momentum. so i know its not getting enough air for that demand, but ill fix that soon also. just want to know if i go with this upgrade then i wont have to worry so much about losing the power on the upper end. when i get the dhp programmer ill take the WOT shifts down some on the rpms, but i wanna keep it about 5900 or so, so i wanna make sure my engine will breathe...N/A
                              • project90tempest
                                • Jul 2005
                                • 19
                                #30
                                Thanks for the info. I'll have to do that this weekend. Here's hoping.
