The Hybrid Build w/Boosted/N20
  • Identity Crisis
    Lost at Birth
    • Jul 2006
    • 295
    I posted this on the v6z24.com board but I wanted to get as much exposure for assistance from as broad of a range of people as I can.
    I started this project out as a 3.1L Valve Train install. Then it moved to a 3.1L Complete mild build, Then it became a 3X00 Hybrid Complete Major Build with N20 and here it sits now.
    3X00 Hybrid Complete Major Build for Turbo and N20.
    My Goal is 350HP (w/125 HP Shot of N20) @ the wheels and a 13.0 Sec 1/4Mile (I know I am being modest with the numbers but I dont want to brag about power I dont have yet)
    Here is a list of what I have bought and what I have yet to buy. Please feel free to add any comments about parts or design that may help me through this build.
    I will not be doing the build by myself. My shop that I deal with will be doing the build but I will be there every step of the way to learn from the PROS and to get my hands dirty on this build.
    PURCHASED
    3.1L Block (to be bored .40 thou)
    Hypereutectic Pistons .40over (Awaiting purchase)
    Garrett T4 Turbo (thanks Syn at least for this)
    Front Mount Intercooler (No Thanks to Syn for ripping a man off)
    3400 heads (want a P&P)
    Crane Cams H272 Camshaft
    Comp Cams LS6 Valve Springs
    Comp Cams 1.6 Ratio Roller Rockers
    Comp Cams Lifters
    Comp Cams Timing Chain
    MSD DIS-4
    MSD Coils
    MSD Interface Blocks
    Accel 19# Injectors
    2bar map sensor
    GTP Prom
    FFP underdrive pulley
    Venom 1000 N20 System
    ZEX N20 Blow down kit
    NOS Bottle Heater
    TO BE PURCHASED
    327 Rods (Wrist Pin Bushing installed)
    Comp Cams Custom Push Rods
    Comp Cams Retainers and locks (Sappy we will talk)
    High Volume Oil Pump
    3.5L UIM (want a P&P) (I NEED THIS Someone sell me one please)
    4.3 TB
    FMU
    3400 Front Cover
    Fidenza Flywheel
    Bulley Stage 3 Clutch
    Beretta Tranny Internals
    LSD
    Performance CV Shafts (What I dont know)
    Exhaust Pipes for Custom Headers
    Piping for FMIC
    Greddy BOV
    Tial External Wastegate
    Boost Guage
    N20 Purge Kit
    N20 Pressure Guage
    Fuel Pressure Guage
    Royal Purple 5W30 Oil
    Bearings, and rings
    Gaskets
    I dont think I have forgotten anything. If so feel free to remind me.
    Here are a few pics of some of the parts that I have now.
    I dont know what this means but "ASS HATS" is funny
  • Guest
    if you can I would try to find a 3100 block. Roller cam and better oiling. roller cam has more potential
    • Identity Crisis
      Lost at Birth
      • Jul 2006
      • 295
      Nice idea but I am already into the parts for this set up and I am not interested in throwing away money now. But from the research that I have obtained this design will give me the most for my money in the way of power.
      • AaronGTR
        boost lover
        • Jan 2004
        • 708
        You're going to need much bigger injectors than that for 350hp. Stock '99 grand am injectors are 19lb/hr and are maxed out by 200hp. Try some 36lb/hr from the grand prix GTP.
        Also some people have had issues with high volume oil pumps. If the block and internals aren't properly machined with the right tolerances etc to need it, the extra flow is pointless and will just cause problems. I believe those pumps are more for circle track cars running race engines, and probably use higher capacity oil pans as well. Stick with the stock pump.
        Other than that, can't comment on the rest 'cause I'm not as familiar with the 3.1 specifics as I am the later engines. Good luck with the build though.
        '97 Grand Prix GT 3800 (sold)
        Gotta love boost!
        • Identity Crisis
          Lost at Birth
          • Jul 2006
          • 295
          Thanks for the info on the pump. I was thinking that the oil pump should be adiquit.
          As for the Injectors yeah i am finding out fast from many people that #19 wont be enough.
          • mfewtrail
            ~600hp worth of 3.1's
            • 170
            Your power to ET estimates need some work. What car is this in? I'm going to guess early 90's J-body..if so, your car probably weighs in at 2700lbs. With 350whp(rougly ~411hp @ the crank assuming 15% drivetrain loss), a J-body should be able to crack 11's w/ traction.
            Matt F.
            TGP 1/4 mile times
            http://photobucket.com/albums/y33/mfewtrail/
            1990 TGP Coupe VIN Database
            • Identity Crisis
              Lost at Birth
              • Jul 2006
              • 295
              Traction will be a big issue as I have seen this on other Jbodies that are boosted.
              But like I have said I am being overly modest on the estimates.
              • Identity Crisis
                Lost at Birth
                • Jul 2006
                • 295
                I am now a little closer to the final Boost products that I am looking for.
                Thanks to HAYESPERFORMANCE I picked up the 3800 Eaton Super charger from a 99SC GM Car.
                SC+TC+N20
                Hope this all works the way I want it to.
                • sil
                  4T60-E killa
                  • Nov 2004
                  • 723
                  tri-power lol sounds fun.
                  looks good, except that you prolly bought alot of stuff before really planning this out.
                  should have went with the 3400 block and 3500 topend imo.
                  but this, if tuned properly will crank out some nice numbers.
                  • Identity Crisis
                    Lost at Birth
                    • Jul 2006
                    • 295
                    It started out as just a remove and replacement of a stock 3.1L then it has grown from there. As for decisions on the Block and Intake that for the most part has not changed. Sure I would like to do the 3500 Conversion and drop it in but at the cost of one in this area no way.
                    I did in fact check in on the costs on several engines and that is why I decided to go the route I am on (Hybrid), it will be an opportunity for me to get my hands dirty again doing a tear down and a rebuild and to learn somethings new on the way.
                    Time is not a factor as this is going to take me some time to complete. But it will be fun non the less. As for money, well I am not rich and I choose to only spend so much on my toy per month, as I have no interest in being one of these people that put so much money into there cars all at once and then they wind up eating nothing but Kraft Dinner every night with water. KWIM?
                    if in the end it is not what I want then I will tear it down and divy up the parts into a new project. In the end I will be happy no matter what.
                    Thanks for the inputs
                    • Identity Crisis
                      Lost at Birth
                      • Jul 2006
                      • 295
                      Update. Trying to find a set of 3500 Heads and 3500 LIM. What GM cars did these come on. And yes I did a search but after going through 7 pages and finding nothing I gave up. Just someone point me int he right direction. I already have the 3500 UIM.
                      Hey last thing is there anyone that can get me a casting # for the heads?
                      Thanks so much.. Ohh and one more thing....Merry Christmas
                      • kflo 93 gt
                        Bangin' Gears
                        • Nov 2003
                        • 238
                        04 - 05? Malibu, and 05 G6s. There's a starting point anyways.
                        14.60 @ 96.33 for now...
                          I got my 3500 from a 04 malibu, and i think that was the only two cars that had them... I could be wrong but car-part only comes up with malibu and g6 04-05 when you search for malibu 04 engine...
                          I take that back, those are the only two cars that Linders has 3500's from...
                          • Identity Crisis
                            Lost at Birth
                            • Jul 2006
                            • 295
                            Does the Montana have the same 3500 heads as the malibu and G6?
                              • 9186
                              Montana came with a 3400, not a 3500.
