How much can you plane 2.8 heads?
  • Arns85GT
    • Feb 2004
    • 140
    I have a Fiero 2.8 and I'd like to raise the compression. The heads were redone and the faces lightly re-milled last year, however, I need more compression.
    How much can be taken off the heads without valves hitting, and what compression ratio will result when you are talking about a stock 2.8 set of heads?
    Arn
    Arn Brown
  • Syn
    The Master Piece
    • Oct 2005
    • 599
    time for pistons bro, do it the right way
    the iron heads increase compression from what i've read. how much idk and if u have aluminum heads i am not sure what else would needed to be changed
    but i'm maken plenty of power with a c/r of 8.8:1
    • sil
      4T60-E killa
      • Nov 2004
      • 723
      i think the most you ever want to plane heads is .020, but my machinnist said .012, this is due to the angle changes at the intake to head surface
      • prophiseer
        Blaspheming Heretic
        • Jun 2006
        • 354
        GM's tech info states no more than .010" - prob for the same reason as stated above.
        The machine shop we deal with has claimed they can go to about .020", but will also require the base of the LIM to be decked a similar amount
        N-body enthusiast:
        {'87 Grand Am SE - 3.0 90* v6} / {'93 Grand Am LE - 3.3 90* v6}
        {'98 Grand Am SE - 2.4 Q4} / {'99 Grand Am GT1 - 3400 60* v6}
        Current Project:
        {'90 Chevrolet C1500 Sport 350TBI}
        • Syn
          The Master Piece
          • Oct 2005
          • 599
          u didn't say if ur heads were iron, but u can try useing the iron head 3.1 head gaskets because they r thinner
          • Ortie666
            • Jul 2005
            • 340
            Or use 3.1L heads with the 3.1 gasket on those 2.8L flat top pistons for a good 12.5:1 compression.. then i dont think you will be complaining about wanting more comp. rather more money for racefuel so u can drive to get grocreys
            Six-t-Six Motorsports
            2.8L Chevette Roadcar
            3.2L Acadian Racecar
              I agree with Ortie666.. switch to the aluminium heads... Gen3 FTW!
              • Arns85GT
                • Feb 2004
                • 140
                Switching to aluminum heads means a whole lot of dough and a whole lot of inconvenience on the engine. I have the Edelbrock Torker II intake and a Holley 390 carb. The exhaust manifolds for a Fiero have to be special do to space limitations. No room for S10 style headers.
                I am trying to avoid the expense of pulling the pistons and doing new pistons and rings. Does anybody know what compression you end up with at .020 shaved off?
                As for the gaskets, I've been wondering about them too. Would copper gaskets be thinner? And would they bump the compression?
                Arn
                Arn Brown
                  • 9185
                  60V6 CR Calculator
                  You'd just have to try to determine how much the volume of the head will change with a.020" taken off. It shouldn't be too hard to guesstimate if you can determine the area of the chamber at the surface of the head. Take that number times .020, convert to cc's, then subract from the stock volume.
