Why does my Bone stock 96 3100 GP seem faster than my modded 95 GP 3100
  • Manitcor
    • 573
    #31
    If you have a 95 car then 97 s about as far as you can go, IIRC they changed ALOT of things in 98 even among the montes. I dont remember the specifics since its been over a year since I did the swap.
    Montes went to the 3400/t65 combo in 2000 however thats also when they aquired a BCM so teres alot of extra work there to get an 00+ PCM to work in a pre-00 car.
    Ben, I was thinking along the same lines you were at first. From my research I determined that it might be possible to either re-code a 1997 Monte Z34 PCM for a 3400 engine since it had a t65 stock. Or some how try to shoe horn a 99+ pcm setup into my car however 99+ systems are depenant upon thier BCMs in ALOT of ways that the older computers are not so your basically talking about re-wiring the entire car.
    The real question is, is how much power are you talking about, I broke down and stayed wit the t60 and had DynoTech build me a new t60 that can handle 400hp. I dont see why you couldnt get a t60 to take the power you need unless your talking about alot more than 400. I tink you could make a t65 work, the devil will be in the details.
    1995 Monte Carlo LS
    3400 SFI 60v6
    • gpse3400
      • 1460
      #32
      Running the '95 program, you might wanna put the stock air box back in. Another thing is is you might be cooling down the exhaust by running 2.5 cat back. Probably works better with the Nitrous
      Lorenzo
      • blackbombshell95
        Kaiō-ken X 10
        • Jun 2004
        • 1386
        #33
        The 75 shot brought me from a steady 16.3 -.4 to a 15.0
        02 GTP - 90* > Failboat
        www.blackbombshell95.com
