1993 grand prix
  • exodus2113
    93 prix LE
    • Oct 2006
    • 8
    1993 grand prix
    my prix has a 3100 in it right now but i would like to get the most power out of the car possible. should i try to build up this 3100 or should i get a diffrent engine. and if so what engine should i get? or what can i do to the engine?
    • 9191
    • 19Cutlass94
      • Apr 2005
      • 770
      + turbo
      3400/Getrag 284 5spd
      350/NV3500 5spd
      2014 Chevrolet Malibu LS
      • blackbombshell95
        Kaiō-ken X 10
        • Jun 2004
        • 1386
        Do a l67 swap, its what everybody else is doing. Just make sure you put a smoke detector in your engine bay because the injectors are known for catching the whole car on fire.
        02 GTP - 90* > Failboat
        www.blackbombshell95.com
        • exodus2113
          93 prix LE
          • Oct 2006
          • 8
          What is an l67?
            • 9191
            L67 = 3800 supercharged
            • exodus2113
              93 prix LE
              • Oct 2006
              • 8
              what makes more power the 3400 with a turbo or the 3800 supercharged?
              • DEI37
                • Jan 2004
                • 516
                Depends on what you want to do with it. There are 800HP SC 3.8's out there. You can probably reliably get to 500HP on mostly stock stuff.
                • exodus2113
                  93 prix LE
                  • Oct 2006
                  • 8
                  500-800 hp?? i wasnt expecting that much what do i need to do to get to there? other then obviously get the 3.8 sc engine.
                  • GPTuner
                    • 54
                    I have a 97 GTP with the L67
                    i'll give you a few specs on what they do stock
                    3.8L supercharged 5 pounds of boost on the stock 3.8" pulley
                    240 HP
                    260 TQ
                    Average mid 14's in the 1/4 stock
                    Bolt on a 3.4" pulley raises your boost to 8 pounds, good for generaly 25 HP right off the bat make a custom 3.5" intake to free up some more power, full exaust will free up some more, those mods with the 3.4 will probably free up at least another 15 HP
                    that site will give you any info you need
                    Shop performance car parts online at PFYC.com! Explore aftermarket & OEM parts like camshafts, spoilers, turbos & more — shop now!
                    ^^^^those sites have almost everything you can think of to make some serious power to the 3800 series II supercharged motor
                    ^^^^^^^^^^^^^^^^^--these guys have stuff for your motor, and they also have kits to swap an L67 into your car
                    All i have is the 3.4 pulley, 160 thermostat, randomtech downpipe/cat, SLP catback, 3.5" fenderwell intake, hacked MAS, dynotech performance tuned PCM, everything else is stock, and im pulling consistant 13.60's at 100-101MPH at the track and the car weighs 3600 pounds with me in it....trust me for the best bang for your buck, the L-67 has major potential
                    http://profile.myspace.com/index.cfm...endid=14262310
