Originally posted by SHOoff
View Post
swapped 3500 heads
3500 short block with 3400 top end.....why would even consider that?! might give you just a tad more compression, but nothing noticible.Last edited by bszopi; 10-30-2006, 08:36 PM.Andy
fastest 1/8: 10.19@ 67.17
fastest 1/4: 16.16@ 82.70
i am using the 3400 upper intake manifold on top of the 3500 lower intake manifold works fine...1996 beretta w/a 04' 3400 3.5 top end, 42.5lb hr, 180*thermo, t3t4 .63ar 60 trim, LC1 WB, FMIC, greddy rs BOV,TIAL 38mm wastegate,791xv,fidanza,stage III clutch,TG LSD,ffp udp,walbro 255 lph,strut tower brace,22 rear sway,30 front sway,92 5sp tranny,92 subframes,all solid mounts,kyb shocks and struts,eibachs,battery in trunk,tgp map sensor,DHP Powrtuner,euro front and rear and more to come soon...mods sitting in boxes waiting install....zo4 kit,GTU wing,and more..
I must not have been clear. 3500 lower did not mean 'bottom end' It meant 'lower intake manifold'Originally posted by torq455 View Post3500 short block with 3400 top end.....why would even consider that?! might give you just a tad more compression, but nothing noticible.
Thanks for the replies though. I'm assuming though that the 3500 UIM flows better than the 3400's though?97 Cavalier RS
3400, Isuzu MK7
yes the 3500 plenum does flow better but until i have the money for the plenum the fpr adapter and the 65mm tb im not swapping ... lol1996 beretta w/a 04' 3400 3.5 top end, 42.5lb hr, 180*thermo, t3t4 .63ar 60 trim, LC1 WB, FMIC, greddy rs BOV,TIAL 38mm wastegate,791xv,fidanza,stage III clutch,TG LSD,ffp udp,walbro 255 lph,strut tower brace,22 rear sway,30 front sway,92 5sp tranny,92 subframes,all solid mounts,kyb shocks and struts,eibachs,battery in trunk,tgp map sensor,DHP Powrtuner,euro front and rear and more to come soon...mods sitting in boxes waiting install....zo4 kit,GTU wing,and more..
Don't expect it to run correctly with that 3bar map once you are boosted. The current version of PT has the option for map scaling to use different size map's, but there is an issue right now with changing map's on boosted cars that were NA from the factory. Specifically with the way they measure barometric pressure. Once you hit boost it will reset the baro to whatever boost you hit and leave it there until you turn off the car so it will mess up your idle. GTP's that come boosted from the factory have something in the program that keeps it from doing this. They haven't fixed it for NA cars yet.Originally posted by rickykline View Post... msd 3 bar map sensor, DHP Powrtuner(and a damn near perfect tune), euro headlamps, euro tails and more to come soon...
Also once you install all this expect your "perfect tune" to go down the drain. I find it hard to believe it's that good... there is always room to improve, especially on a hybrid engine. That and like you said there aren't as many of us tuning 3400's and we haven't been doing it as long. We all have a lot to learn yet. Once you boost it you are going to need bigger injectors period! And your volumetric efficiency is going to totally change too. Add a cam and it changes things even more. The first thing I learned is that changing that much on the engine totally changes how it runs and it doesn't always react like you expect to tuning changes. It is a very long tedious process. Not trying to bring you down with all this... just giving you a heads-up.mods sitting in boxes waiting install.... ( t3 t4 63ar 60 trim, front mount intercooler, greddy rs BOV, tial 38mm wastegate...
as for manifolds i am using the stock 3400 manifolds.. and am about to have the cross over made for my turbo..
no issues with the fuel rail.. my user name on dhp is rickykline.. i dont post much at all i spend most my time working on the car and there arent alot of 3400 enthuasist there all 3800 guys lol..
I agree with everyone else, you need to ditch those 3400 manifolds. They will be restrictive even for a turbo setup. Use the 3500 mani's if you must, or better yet make some custom turbo manifolds.'97 Grand Prix GT 3800 (sold)
Gotta love boost!
once my income allows i will go with turbo manifolds.. but for now i just need to get this 3k worth of parts on... lol1996 beretta w/a 04' 3400 3.5 top end, 42.5lb hr, 180*thermo, t3t4 .63ar 60 trim, LC1 WB, FMIC, greddy rs BOV,TIAL 38mm wastegate,791xv,fidanza,stage III clutch,TG LSD,ffp udp,walbro 255 lph,strut tower brace,22 rear sway,30 front sway,92 5sp tranny,92 subframes,all solid mounts,kyb shocks and struts,eibachs,battery in trunk,tgp map sensor,DHP Powrtuner,euro front and rear and more to come soon...mods sitting in boxes waiting install....zo4 kit,GTU wing,and more..
