2.8L (GEN 2) Engine Specifications
    • 9190
    2.8L (Gen II) Engine Specifications
    General Data:
    All dimensions are in millimeters
    Type
    60 degree V6
    Displacement
    2.8L
    RPO
    LB6
    Bore
    89.0
    Stroke
    76.0
    Deck Height
    224
    Compression Ratio
    8.9:1
    Firing Order
    1-2-3-4-5-6
    Oil Pressure
    69 kPa @500
    RPM; 205-380 kPa @ 2000 RPM
    (10 psi @ 500 RPM;
    30-55 psi @ 2000R RPM)
    Cylinder
    Bore:
    Diameter
    88.983-89.017
    Out of Round
    0.013 (Maximum)
    Taper - Thrust
    Side
    0.013 (Maximum)
    Piston:
    Clearance
    0.023-0.056
    Piston Ring:
    COMPRESSION
    Groove Clearance
    Top
    0.051.089
    Second
    0.051.089
    Gap
    Top
    0.25-0.50
    Second
    0.25-0.50
    OIL
    Groove Clearance
    0.199
    (Maximum)
    Gap
    0.25-076
    Piston Pin:
    Diameter
    22.992-22.997
    Clearance
    0.0064-0.0091
    Fit in Rod
    Press
    Crankshaft:
    Main
    Journal Diameter
    67.241-67.267
    Taper
    0.005 (Maximum)
    Out Of Round
    0.005 (Maximum)
    Main Bearing
    Clearance
    0.030-0.069
    Crankshaft End
    Play
    0.05-0.20
    Crankpin
    Diameter
    50.757-50.785
    Taper
    0.005 (Maximum)
    Out of Round
    0.005 (Maximum)
    Rod Bearing
    Clearance
    0.036-0.091
    Rod Side
    Clearance
    0.36-0.68
    Camshaft:
    Lift
    Intake
    6.67
    Exhaust
    6.93
    Journal Diameter
    47.442-47.790
    Journal Clearance
    0.02-0.10
    Valve System:
    Lifter
    Hydraulic
    Rocker Arm Ratio
    1.50:1
    Valve
    Lash
    Intake
    1-1/2 Turns Down from Zero Lash
    Exhaust
    Face Angle
    (Intake & Exhaust)
    45 degrease
    Seat Angle
    (Intake & Exhaust)
    46 degrease
    Seat Runout
    (Intake & Exhaust)
    0.02
    Seat
    Width
    Intake
    1.55-1.85
    Exhaust
    1.70-2.01
    Stem Clearance
    0.025-0.069
    Valve
    Spring
    Free Length
    48.51
    Pressure
    Kg @ mm
    Closed
    40.8 @ 43.2
    Open
    97 @ 32.79
    Installed Height
    40.01
    Valve
    Spring
    Damper
    Free Length
    48.51
    Approx # of Coils
    4
    Fastener Tightening Specifications
    Item
    Nm
    Ft Lbs
    Camshaft Sprocket Bolts
    24
    18
    Connecting Rod Bolt Nuts
    51
    37
    Crankshaft Damper Bolt
    77
    104
    Cylinder Head Bolt (apply thread sealant
    to bolts)
    First Pass
    45
    33 Final Pass Add 90 Degrees
    *Manifold Side*
    6 2 3 7
    5 1 4 8
    * Outer Side *
    Exhaust Manifold Bolt
    24
    18
    Flywheel Bolt
    71
    52
    Front Timing Cover Case Bolt 8mm 18-35 13-25 10mm 27-47 20-35
    Lower Intake Manifold Bolt First Pass 22 16 Final Pass 31 23
    Upper Intake Manifold Bolt
    22
    16 Main Bearing Cap 99 73
    Oil Pan Bolt
    6mm
    8-12
    6-9 8mm 19-30 14-22
    Oil Pump Bolt
    41
    30
    Rocker Arm Nut
    24
    18
    Timing Chain Damper Bolt
    20
    15
