3400 Engine Specifications
    • 9191
    3400 Engine Mechanical Specifications
    Application
    Specification
    Metric
    English General Data Engine Type
    60° V-6 Displacement
    3.4L
    204 cu in RPO (VIN Code)
    LA1 (E) Bore
    92 mm
    3.62 in Stroke
    84 mm
    3.31 in Deck Height
    224 mm
    8.818 in Compression Ratio
    9.6:1 Firing Order
    1-2-3-4-5-6
    Oil Pressure - Warm
    103 kPa
    15 psi @ 1100 RPM Cylinder
    Bore
    Diameter
    92.019-92.037 mm
    3.6228-3.6235 in Out Of Round Maximum
    0.007 mm
    0.0003 in Taper -- Thrust Side Maximum
    0.010 mm
    0.0004 in Piston Diameter-Gaged on the skirt 13 mm (0.51 in) below
    the centerline of the piston pin bore
    91.970-91.988 mm
    3.6209-3.6216 in Clearance
    0.032-0.068 mm
    0.0013-0.0027 in Pin Bore
    23.006-23.013 mm
    0.9057-0.9060 in Piston Ring Top Groove Side Clearance
    0.04-0.075 mm
    0.002-0.0033 in Second Groove Side Clearance
    0.04-0.09 mm
    0.002-0.0035 in Top Ring Gap
    0.15-0.36 mm
    0.006-0.014 in Second Ring Gap
    0.48-0.74 mm
    0.0197-0.0280 in Oil Ring Groove Clearance
    0.48-0.20 mm
    0.008 in Gap with segment at 92.0 mm (3.62 in)
    0.25-0.75 mm
    0.0098-0.05 in Piston Pin Diameter
    22.9915-22.9964 mm
    0.9052-0.9054 in Clearance In Piston
    0.0096-0.0215 mm
    0.0004-0.0008 in Fit In Rod
    (-)0.0469-(-)0.017 mm
    press fit
    0.0006-0.0018 in Crankshaft Main Journal Diameter
    67.239-67.257 mm
    2.6473-2.6483 in Main Journal Taper
    0.005 mm
    0.0002 in Out Of Round - Max
    0.005 mm
    0.0002 in Flange Runout - Max
    0.04 mm
    0.0016 in Cylinder Block Main Bearing Bore Diameter
    72.155-72.168 mm
    2.8407-2.8412 in Crankshaft Main Bearing Inside Diameter
    67.289-67.316 mm
    2.6492-2.6502 in Main Bearing Clearance
    0.019-0.064 mm
    0.0008-0.0025 in Main Thrust Bearing Clearance
    0.032-0.077 mm
    0.0012-0.0030 in Crankshaft End Play
    0.060-0.210 mm
    0.0024-0.0083 in Crankshaft Flange Runout - Max
    0.04 mm
    0.0016 in Connecting
    Rod
    Rod Bearing Journal Diameter
    50.768-50.784 mm
    1.9987-1.9994 in Rod Bearing Journal Taper - Max
    0.005 mm
    0.0002 in Rod Bearing Journal Out Of Round - Max
    0.005 mm
    0.0002 in Rod Bearing Bore Diameter
    53.962-53.984 mm
    2.124-2.125 in Rod Inside Bearing Diameter
    50.812-50.850 mm
    2.000-2.002 in Rod Bearing Journal Clearance
    0.018-0.062 mm
    0.0007-0.0024 in Rod Side Clearance
    0.18-0.44 mm
    0.007-0.017 in Camshaft Lobe Lift (Intake and Exhaust)
    6.9263 mm
    0.2727 in Journal Diameter
    47.45-47.48 mm
    1.868-1.869 in Camshaft Bearing Bore Diameter-Front and Rear
    51.03-51.08 mm
    2.009-2.011 in Camshaft Bearing Bore Diameter-Middle #2 and #3
    50.77-50.82 mm
    1.999-2.001 in Camshaft Bearing Inside Diameter
    47.523-47.549 mm
    1.871-1.872 in Journal Clearance
    0.026-0.101 mm
    0.001-0.0039 in Journal Runout - Max
    0.025 mm
    0.001 in Valve System Roller Lifter
    Hydraulic Rocker Arm Ratio
    1.60:1 Valve Face Angle
    45° Seat Angle
    46° Valve Seat Runout
    0.050 mm
    0.002 in Seat Width-Intake
    1.55-1.80 mm
    0.061-0.071 in Seat Width-Exhaust
    1.70-2.0 mm
    0.067-0.079 in Valve Margin - Minimum Intake
    2.10 mm
    0.083 in Valve Margin - Minimum Exhaust
    2.70 mm
    0.106 in Valve Stem Clearance
    0.026-0.068 mm
    0.0010-0.0027 in Valve Spring Valve Springs Free Length
    48.5 mm
    1.89 in Valve Springs Load (Closed)
    320 N @ 43.2 mm
    75 lb @ 1.701 in Valve Springs Load (Open)
    1036 N @ 32 mm
    230 lb @ 1.260 in Installed Height Intake-Exhaust
    43.2 mm
    1.701 in Approx. # or coils
    6.55 Oil Pump Gear Lash
    0.094-0.195 mm
    0.0037-0.0077 in Gear Pocket Depth
    30.52-30.58 mm
    1.202-1.204 in Gear Pocket Diameter
    38.176-38.226 mm
    1.503-1.505 in Oil Pump
    Gear
    Length
    30.45-30.48 mm
    1.199-1.200 in Diameter
    38.05-38.10 mm
    1.498-1.500 in Side Clearance
    0.038-0.088 mm
    0.001-0.003 in End Clearance
    0.040-0.125 mm
    0.002-0.005 in Valve to Bore Clearance
    0.038-0.089 mm
    0.0015-0.0035 in Cylinder Head CC
    28.6cc
    Piston CC
    28.6cc
    Head Gasket Bore
    3.750"
    Head Gasket Thickness
    .060"
    Piston Deck Height
    -.020"
    Fastener Tightening Specifications (LG8 and LA1)
    Application
    Specification
    Metric
    English Accelerator Control
    Cable Bracket Bolt/Nut
    10 N·m
    89 lb in Camshaft Position Sensor
    Bolt
    10 N·m
    89 lb in Camshaft Sprocket Bolt
    140 N·m
    103 lb ft Camshaft Thrust Plate
    Screw
    10 N·m
    89 lb in Connecting Rod Bearing
    Cap Nut
    20 N·m + 75°
    15 lb ft + 75° Coolant Drain Plug
    19 N·m
    14 lb ft Coolant Temperature
    Sensor
    23 N·m
    17 lb ft Crankshaft Balancer Bolt
    103 N·m
    76 lb ft Crankshaft Main Bearing
    Cap Bolt/Stud
    50 N·m +77°
    37 lb ft + 77° Crankshaft Oil Deflector
    Nut
    25 N·m
    18 lb ft Crankshaft Position
    Sensor Bolt -- Front Cover
    10 N·m
    89 lb in Crankshaft Position
    Sensor Stud -- Side of Engine Block
    11 N·m
    98 lb in Crankshaft Position
    Sensor Wiring Bracket Bolt
    27 N·m
    20 lb ft Cylinder Head Bolt
    60 N·m + 95°
    44 lb ft + 95° Drive Belt Shield Bolt
    10 N·m
    89 lb in Drive Belt Tensioner
    Bolt
    50 N·m
    37 lb ft EGR Valve to EGR Valve
    Pipe Bolt
    25 N·m
    18 lb ft EGR Valve Adapter Pipe
    to Exhaust Manifold Nut
    25 N·m
    18 lb ft Engine Flywheel Bolt
    71 N·m
    52 lb ft Engine Front Cover Bolt
    -- Large
    55 N·m
    41 lb ft Engine Front Cover Bolt
    -- Medium
    47 N·m
    35 lb ft Engine Front Cover Bolt
    -- Small
    21 N·m
    15 lb ft Engine Mount Bracket
    Bolt
    58 N·m
    43 lb ft Engine Mount Lower Nut
    43 N·m
    32 lb ft Engine Mount Strut and
    Lift Bracket Bolt -- Engine Left Rear
    70 N·m
    52 lb ft Engine Mount Strut
    Bolt/Nut
    48 N·m
    35 lb ft Engine Mount Strut
    Bracket Bolt -- Upper Radiator Support
    28 N·m
    21 lb ft Engine Mount Strut
    Bracket Bolt -- Vehicle Right Side
    50 N·m
    37 lb ft Engine Mount Upper Nut
    47 N·m
    35 lb ft Engine Oil Pressure
    Indicator Switch
    13 N·m
    115 lb in Engine Wiring Harness
    Bracket Bolt
    13 N·m
    115 lb in Exhaust Crossover Pipe
    Heat Shield Bolt
    10 N·m
    89 lb in Exhaust Crossover Pipe
    Nut/Stud
    25 N·m
    18 lb ft Exhaust Manifold Heat
    Shield Bolt
    10 N·m
    89 lb in Exhaust Manifold Nut
    16 N·m
    12 lb ft Exhaust Manifold Stud
    18 N·m
    13 lb ft Fuel Feed Pipe to Fuel
    Injector Rail Nut
    17 N·m
    13 lb ft Fuel Injector Rail Bolt
    10 N·m
    89 lb in Fuel Pipe Bracket
    Bolt/Stud
    50 N·m
    37 lb ft Fuel Pipe Clip Bolt
    8 N·m
    71 lb in Fuel Return Pipe to Fuel
    Injector Rail Nut
    17 N·m
    13 lb ft Generator Bracket and
    Front Engine Lift Hook Bolt
    50 N·m
    37 lb ft Heated Oxygen Sensor
    42 N·m
    31 lb ft Heater Inlet Pipe Nut
    25 N·m
    18 lb ft Ignition Coil Bracket
    Bolt/Nut/Stud
    25 N·m
    18 lb ft Intake Manifold Coolant
    Pipe Bolt
    10 N·m
    89 lb in Knock Sensor
    19 N·m
    14 lb ft
    Lower Intake Manifold
    Bolt - Center
    • First Pass
    7 N·m
    62 lb in
    • Final Pass
    13 N·m
    115 lb in
    Bolt - Corner
    • First Pass
    13 N·m
    115 lb in
    • Final Pass
    25 N·m
    18 lb ft MAP Sensor Bolt
    5 N·m
    44 lb in Oil Cooler Connector
    50 N·m
    37 lb ft Oil Cooler Hose Fitting
    19 N·m
    14 lb ft Oil Cooler Pipe Bracket
    Bolt
    10 N·m
    89 lb in Oil Filter
    13 N·m
    115 lb in Oil Filter Bypass Hole
    Plug
    19 N·m
    14 lb ft Oil Filter Fitting
    39 N·m
    29 lb ft Oil Gallery Plug -- 1/4
    inch
    19 N·m
    14 lb ft Oil Gallery Plug -- 3/8
    inch
    33 N·m
    24 lb ft Oil Level Indicator Tube
    Stud
    25 N·m
    18 lb ft Oil Level Sensor Bolt
    10 N·m
    89 lb in Oil Pan Bolt
    25 N·m
    18 lb ft Oil Pan Drain Plug
    25 N·m
    18 lb ft Oil Pan Side Bolt
    50 N·m
    37 lb ft Oil Pump Cover Bolt
    10 N·m
    89 lb in Oil Pump Drive Clamp
    Bolt
    36 N·m
    27 lb ft Oil Pump Mounting Bolt
    41 N·m
    30 lb ft Spark Plug
    • Spark Plug - Initial Installation
    20 N·m
    15 lb ft
    • Spark Plug - Reinstallation
    15 N·m
    11 lb ft Thermostat Bypass Pipe
    to Cylinder Head Nut
    25 N·m
    18 lb ft Thermostat Bypass Pipe
    to Engine Front Cover Bolt
    12 N·m
    106 lb in Thermostat Bypass Pipe
    to Throttle Body Nut
    25 N·m
    18 lb ft Throttle Body Bolt/Stud
    25 N·m
    18 lb ft Timing Chain Dampener
    Bolt
    21 N·m
    15 lb ft Upper Intake Manifold
    Bolt/Stud
    25 N·m
    18 lb ft Valve Lifter Guide Bolt
    10 N·m
    89 lb in Valve Rocker Arm Bolt
    19 N·m + 30°
    14 lb ft+ 30° Valve Rocker Arm Cover
    Bolt
    10 N·m
    89 lb in Water Outlet Bolt
    25 N·m
    18 lb ft Water Pump Bolt
    10 N·m
    89 lb in Water Pump Pulley Bolt
    25 N·m
    18 lb ft
