3900 Engine Specifications
    • 9191
    3900 Engine Mechanical Specifications
    Application
    Specification Metric English
    General Data
    Engine Type 60 degree V-6 Displacement 3.9L 238 cu in RPO LZ9 VIN 1 Bore 99 mm 3.90 in Stroke 84 mm 3.31 in Compression
    Ratio
    9.8:1 Firing Order 123456 Spark Plug
    Gap
    1.00 mm 0.040 in
    Block
    Camshaft
    Bearing Bore Diameter - Front and Rear
    55.26-55.31 mm
    2.175-2.177 in
    Camshaft
    Bearing Bore Diameter - Middle #2, #3
    54.75-54.80 mm
    2.155-2.157 in
    Crankshaft
    Main Bearing Bore Diameter
    72.1535-72.0695 mm
    2.840-2.841 in
    Crankshaft Main Bearing
    Bore Out-of-Round
    0.008 mm 0.00031 in Cylinder Bore Diameter
    99.000-99.018 mm
    3.897-3.898 in
    Cylinder Bore
    Out-of-Round - Diameter - Production
    0.026 mm 0.0010 in Cylinder Bore
    Out-of-Round - Diameter - Service
    0.030 mm 0.0011 in Cylinder Bore
    Taper - Production
    Taper - Service
    0.030 mm 0.0011 in Cylinder Head Deck Height 224 mm 8.818 in Cylinder Head Deck
    Surface Flatness
    0.05 mm
    per 150 mm
    0.0019 in
    per 5.905 in
    Valve Lifter Bore
    Diameter
    21.417-21.455 mm
    0.843-0.844 in
    Camshaft
    Camshaft
    Bearing Inside Diameter
    51.500-51.525 mm
    2.028-2.029 in
    Camshaft
    Journal Diameter
    51.415-51.440 mm
    2.024-2.025 in
    Camshaft
    Journal Out-of-Round
    0.025 mm 0.001 in Camshaft
    Lobe Lift - Exhaust
    6.9263 mm 0.2727 in Camshaft
    Lobe Lift - Intake
    6.9263 mm 0.2727 in
    Cooling System
    Thermostat
    Full Open Temperature
    195 degrees
    Connecting Rod
    Connecting
    Rod Bearing Clearance
    0.018-0.062 mm
    0.0007-0.0024 in
    Connecting
    Rod Bore Diameter
    60.322-60.338 mm
    2.375-2.376 in
    Connecting
    Rod Bore Out-of-Round
    0.006 mm 0.00023 in Connecting
    Rod Length - Center to Center
    150 mm 5.9 in Connecting
    Rod Side Clearance
    0.200-0.241 mm
    0.008-0.009 in
    Crankshaft
    Connecting
    Rod Journal Diameter
    57.122-57.138 mm
    2.248-2.249 in
    Connecting
    Rod Journal Out-of-Round
    0.005 mm 0.0002 in Connecting
    Rod Journal Taper
    0.005 mm 0.0002 in Connecting Rod Journal
    Width
    21.92-22.08 mm
    0.863-0.869 in
    Crankshaft End Play
    0.060-0.210 mm
    0.0024-0.0083 in
    Clearance - Except #3
    0.019-0.064 mm
    0.0008-0.0025 in
    Clearance - #3 Thrust Bearing
    0.032-0.077 mm
    0.0012-0.0030 in
    Crankshaft Main Journal
    Out-of-Round
    0.005 mm 0.0002 in Crankshaft Main Journal
    Taper
    0.005 mm 0.0002 in Crankshaft Rear Flange
    Runout
    0.04 mm 0.0016 in
    Cylinder Head
    Combustion
    Chamber Depth - at Measurement Point
    2.2 mm 0.087 in Surface
    Finish - Maximum
    2.8 RA Surface
    Flatness - Block Deck
    0.08 mm
    per 152 mm
    0.003 in
    per 6 in
    Surface
    Flatness - Exhaust Manifold Deck
    0.1 mm 0.004 in Surface
    Flatness - Intake Manifold Deck
    0.1 mm 0.004 in Valve Guide
    Bore - Exhaust
    8.01 mm 0.315 in Valve Guide
    Bore - Intake
    Installed Height
    16.6 mm 0.654 in
    Lubrication System
    Oil Capacity
    - with Filte
    3.8 liter 4.0 quarts Oil Pressure
    - @ 1850 RPM
    207-310 kPa 30-45 PSI
    Oil Pump
    Gear
    Diameter
    38.05-38.10 mm
    1.498-1.500 in
    Gear Pocket
    - Dept
    30.52-30.58 mm
    1.202-1.204 in
    Gear Pocket
    - Diameter
    38.176-38.226 mm
    1.503-1.505 in
    Gears Lash
    0.094-0.195 mm
    0.0037-0.0077 in
    Relief
    Valve-to-Bore Clearance
    0.038-0.089 mm
    0.0015-0.0035 in
    Pin Piston Pin Clearance to
    Connecting Rod Bore - Press Fit
    -0.004 to -0.021 mm
    -0.0001 to -0.0008 in
    Piston Pin Bore
    0.002-0.010 mm
    0.00008-0.0004 in
    Piston Pin Diameter
    23.952-23.955 mm
    0.942-0.943 in
    Piston Pin Length
    64.21-64.44 mm
    2.57-2.53 in
    Piston Piston Diameter -
    Production
    98.970-99.008 mm
    3.896-3.897 in
    Piston Diameter - Service
    Limit
    98.950 mm 3.895 in Piston Pin Bore Diameter
    23.957-23.962 mm
    0.943 in Piston Ring Groove Width
    1.22-1.24 mm
    0.048-0.049 in
    Piston to Bore Clearance
    - Production
    -0.008 to +0.048 mm
    -0.0003 to +0.0018 in
    Piston to Bore
    Clearance - Service Limit - Maximum
    0.080 mm 0.003 in Piston Ring
    End Gap
    First
    Compression Ring
    0.15-0.30 mm
    0.006-0.011 in
    Second
    Compression Ring
    0.25-0.45 mm
    0.009-0.017 in
    Oil Control
    Ring
    0.15-0.65 mm
    0.06-0.025 in
    Piston Ring to Groove Clearance
    First
    Compression Ring
    0.03-0.065 mm
    0.001-0.002 in
    Second
    Compression Ring
    0.02-0.055 mm
    0.0007-0.002 in
    Oil Control
    Ring
    0.01 mm 0.004 in
    Piston Ring Thickness
    First
    Compression Ring
    1.175-1.190 mm
    0.046-0.047 in
    Second
    Compression Ring
    1.475-1.490 mm
    0.058 in Oil Control
    Ring - Maximum
    2.50 mm 0.098 in Valves Valve Face
    Angle
    45 degrees Valve Seat
    Angle
    46 degrees Valve Seat
    Depth - Exhaust - From Deck Face
    8.9-9.1 mm
    0.350-0.358 in
    Valve Seat
    Depth - Intake - From Deck Face
    7.9-8.1 mm
    0.311-0.318 in
    Valve Seat Width -
    Exhaust
    1.70-2.0 mm
    0.067-0.079 in
    Valve Seat Width - Intake
    1.55-1.80 mm
    0.061-0.071 in
    Valve Stem-to-Guide
    Clearance
    0.026-0.068 mm
    0.0010-0.0027 in
    Valve
    Lifters/Push Rods
    Push Rod Length - Intake 146.0 mm 5.75 in Push Rod Length - Exhaust 152.5 mm 6.0 in Valve Springs Valve Spring Free Length 48.5 mm 1.89 in Valve Spring Installed
    Height
    43.2 mm 1.701 in Valve Spring Load -
    Closed
    320 N
    43.2 mm
    75 lb
    1.701 in
    Valve Spring Load - Open 1036 N
    32 mm
    230 lb 1.260 in
    Valve Spring Total Number
    of Coils
    6.55 Fastener Tightening Specifications
    Application
    Specification Metric English Camshaft Position Sensor
    Bolt
    10 N·m 89 lb in Camshaft
    Sprocket Bolt
    140 N·m 103 lb ft Camshaft
    Thrust Plate Screw
    10 N·m 89 lb in
    Connecting Rod Bearing Cap Bolt
    • First Pass
    25 N·m 18 lb ft
    • Final Pass
    110 degrees Coolant
    Drain Plug
    19 N·m 14 lb ft Coolant
    Temperature Sensor
    23 N·m 17 lb ft Crankshaft
    Balancer Bolt
    160 N·m 118 lb ft
    Crankshaft Main Bearing Cap Bolt/Stud
    • First Pass
    50 N·m 37 lb ft
    • Final Pass
    77 degrees Crankshaft
    Oil Deflector Nut
    25 N·m 18 lb ft Crankshaft
    Position Sensor Stud - Side of Engine Block
    10 N·m 89 lb in
    Cylinder Head Bolt
    • First Pass
    60 N·m 44 lb ft
    • Final Pass
    95 degrees Cylinder Head Plug 20 N·m 15 lb ft Drive Belt
    Tensioner Bolt
    50 N·m 37 lb ft EGR Valve Assembly Bolt 30 N·m 22 lb ft EGR Valve Pipe Bolt - EGR 25 N·m 18 lb ft EGR Valve Pipe
    Bolt - Exhaust Manifold
    30 N·m 22 lb ft
    Engine Front Cover Bolt
    • Large Bolt
    55 N·m 41 lb ft
    • Medium Bolt
    55 N·m 41 lb ft
    • Small Bolt
    27 N·m 20 lb ft Engine Mount
    Strut and A/C Compressor Bracket Bolt
    50 N·m 37 lb ft Engine Mount Strut and
    Generator Bracket Bolt
    Strut and Lift Bracket Bolt - Engine Lift Rear
    Strut and Support Bracket Bolt
    25 N·m 18 lb ft Engine Oil
    Pressure Indicator Switch
    16 N·m 12 lb ft Engine
    Wiring Harness Bracket Bolt
    13 N·m 115 lb in EVAP Purge Valve Bolt 10 N·m 89 lb in Exhaust
    Manifold Heat Shield Bolt
    Manifold Nut
    16 N·m 12 lb ft Exhaust
    Manifold Stud
    18 N·m 13 lb ft Flywheel
    Bolt
    70 N·m 52 lb ft Front Oil Gallery
    Plug - Small
    19 N·m 14 lb ft Front Oil Gallery
    Plug - Large
    33 N·m 24 lb ft Fuel Feed
    Pipe to Fuel Injector Rail Bolt
    10 N·m 89 lb in Fuel
    Injector Rail Bolt
    10 N·m 89 lb in Heated
    Oxygen Sensor
    42 N·m 31 lb ft Heater Inlet
    Pipe Nut
    25 N·m 18 lb ft Heater Inlet
    Pipe Stud
    35 N·m 26 lb ft Ignition
    Coil Bracket Bolt/Nut/Stud
    25 N·m 18 lb ft Intake
    Manifold Coolant Pipe Bolt
    10 N·m 89 lb in Knock Sensor 25 N·m 18 lb ft Lower Intake
    Manifold Bolt - Center
    20 N·m 15 lb ft Lower Intake Manifold
    Bolt - Corner
    25 N·m 18 lb ft MAP Sensor
    Bolt
    10 N·m 89 lb in Oil Filter 30 N·m 22 lb ft Oil Filter
    Adapter Bolt
    25 N·m 18 lb ft Oil Filter
    Bypass Hole Plug
    19 N·m 14 lb ft Oil Filter
    Fitting
    39 N·m 29 lb ft Oil Level
    Indicator Tube Bolt
    25 N·m 18 lb ft Oil Pan Bolt 25 N·m 18 lb ft Oil Pan
    Drain Plug
    25 N·m 18 lb ft Oil Pan Side
    Bolt
    50 N·m 37 lb ft Oil Pump
    Cover Bolt
    10 N·m 89 lb in Oil Pump
    Drive Clamp Bolt
    36 N·m 27 lb ft Oil Pump
    Mounting Bolt
    41 N·m 30 lb ft PCV Tube Clip bolt - Foul
    Air
    10 N·m 89 lb in Piston Oil Nozzle Bolt 10 N·m 89 lb in Rear Oil Gallery
    Plug - 1/4 inch
    19 N·m 14 lb ft Rear Oil Gallery
    Plug - 3/8 inch
    33 N·m 24 lb ft Spark Plug 15 N·m 11 lb ft Thermostat
    Bypass Pipe to Engine Front Cover Bolt
    10 N·m 89 lb in Thermostat
    Bypass Pipe to Throttle Body Nut/Bolt
    10 N·m 89 lb in Throttle
    Body Bolt
    10 N·m 89 lb in Throttle Body Stud 6 N·m 53 lb in Timing Chain
    Dampener Bolt
    21 N·m 15 lb ft Upper Intake
    Manifold Bolt/Stud
    25 N·m 18 lb ft Valve Lifter
    Guide Bolt
    10 N·m 89 lb in Valve Rocker
    Arm Bolt
    32 N·m 24 lb ft Valve Rocker
    Arm Cover Bolt
    10 N·m 89 lb in Water Outlet
    Bolt
    25 N·m 18 lb ft Water Pump
    Bolt
    10 N·m 89 lb in Water Pump
    Pulley Bolt
    25 N·m 18 lb ft
