3.4L (DOHC) Engine Specifications
    • 9191
    3.4L (DOHC) Engine Mechanical Specifications
    Application
    Millimeters
    Inches General Data Engine Type
    60° V-6 Displacement
    204 Cu In Liter (VIN)
    3.4 (X) RPO
    LQ1 Bore
    92
    3.622 Stroke
    84
    3.307 Deck Height
    224
    8.818 Compression Ratio
    9.50:1 Firing Order
    1-2-3-4-5-6 Oil Pressure @ Operating Temperature
    103 kPa @ 1100 RPM
    15 psi min @ 1100 RPM Cylinder Bore Diameter
    92.020-92.038
    3.6228-3.6235 Out Of Round Maximum
    0.010
    0.0004 Taper -- Thrust Side Maximum
    0.013
    0.00051 Center Distance
    111.76
    4.4 Piston Diameter-gauged at skirt 10.44 mm
    (0.413 in) below centerline of piston pin bore
    91.985-92.000
    3.6215-3.6220 Clearance
    0.020-0.052
    0.0008-0.0020 Pin Bore
    23.003-23.010
    0.9056-0.9059 Piston Ring Compression Groove Clearance 1st and 2nd
    0.033-0.079
    0.0013-0.0031 Gap (at gauge diameter) 1st
    0.20-0.45
    0.008-0.018 Gap (at gauge diameter) 2nd
    0.56-0.81
    0.022-0.032 Oil Groove Clearance
    0.028-0.206
    0.0011-0.0081 Gap (segment at gauge diameter)
    0.25-0.76
    0.0098-0.0299 Tension 1st
    27.6 N
    6.2 lbs Tension 2nd
    19.8 N
    4.5 lbs Tension Oil
    31.2 N
    7.0 lbs Piston Pin Diameter
    22.9915-22.9964
    0.9052-0.9054 Clearance
    0.0066-0.0185
    0.00026-0.00073 Fit In Rod
    0.0165-0.0464
    0.0006-0.0018 Crankshaft Main Journal Diameter-All
    67.239-67.257
    2.6472-2.6479 Taper-Maximum
    0.005
    0.0002 Out Of Round-Maximum
    0.005
    0.0002 Cylinder Block Main Bearing Bore Diameter
    72.155-72.168
    2.8407-2.8412 Crankshaft Main Bearing Inner Diameter
    67.289-67.316
    2.6492-2.6502 Main Bearing Clearance
    0.019-0.064
    0.0008-0.0025 Main Thrust Bearing Clearance
    0.032-0.077
    0.0013-0.0030 Crankshaft End Play
    0.06-0.21
    0.002-0.008 Crankpin Diameter
    50.768-50.784
    1.9987-1.9994 Taper-Maximum
    0.005
    0.005
    0.0002 Rod Bearing Bore Diameter
    53.962-53.984
    2.124-2.125 Rod Inner Bearing Diameter
    50.812-50.850
    2.000-2.002 Rod Bearing Clearance
    0.018-0.062
    0.0007-0.0024 Rod Side Clearance
    0.18-0.44
    0.0071-0.0173 Camshaft Lobe Lift (Intake)
    9.398 @ 108° Crank ATDC
    0.370 @ 108° Crank ATDC Lobe Lift (Exhaust)
    9.389 @ 115° Crank BTDC
    0.370 @ 115° Crank BTDC Timing Reference Set Position with Camshaft
    Timing Flats in Clamped Position-Right Bank
    TDC-1Piston Exhaust Stroke +/- 2° of Crankshaft Timing Reference Set Position with Camshaft
    Timing Flats in Clamped Position-Left Bank
    TDC-4 Piston Exhaust Stroke +/- 2° of Crankshaft Journal Diameter
    54.973-55.001
    2.1643-2.1654 Bore Inside Diameter
    55.050-55.075
    2.1673-2.1683 Journal Clearance
    0.049-0.102
    0.0019-0.0040 Valve System Lifter
    Hydraulic Face Angle
    45° Seat Angle
    46° Seat Runout-Maximum
    0.075
    0.0030 Seat Width Intake
    1.25-1.50
    0.0492-0.0591 Exhaust
    1.60-1.90
    0.063-0.0748 Valve Margin-Minimum
    0.75
    0.029 Stem Clearance Intake
    0.028-0.066
    0.0011-0.0026 Stem Clearance Exhaust
    0.046-0.084
    0.0018-0.0033 Valve Spring Free Length
    42.04
    1.6551 Load (Closed)-All
    289 N @ 35.56
    65 lb @ 1.400 Load (Open)-All
    711 N @ 26.16
    160 lb @ 1.030 Approximate Number of Active Coils
    4 Oil Pump Valve to Bore Clearance
    0.038-0.089
    0.0015-0.0035 Gear Lash
    0.094-0.195
    0.0037-0.0077 Gear Pocket Depth
    30.53-30.61
    1.202-1.205 Diameter
    38.202-38.252
    1.504-1.506 Gear Length
    30.45-30.48
    1.199-1.20 Diameter
    38.05-38.10
    1.498-1.50 Side Clearance
    0.08-0.10
    0.003-0.004 End Clearance
    0.05-0.152
    0.002-0.006 3.4L (DOHC) Fastener Tightening Specifications
    Application
    N·m
    Lb Ft
    Lb In Accelerator Control Cable Bracket Bolt
    10
    89 Accelerator Control Cable Bracket Nut
    10
    89 Camshaft Carrier Cover Bolt
    11
    97 Camshaft Carrier Thrust Plate Bolt
    10
    89 Camshaft Carrier Thrust Plate Cover Bolt
    10
    89 Camshaft Drive Belt Cover Bolt
    10
    89 Camshaft Drive Sprocket Bolt
    130
    96
    -- Camshaft Housing Assembly Bolt
    27
    20
    -- Camshaft Position Sensor Bolt
    50
    37
    -- Connecting Rod Cap Nut
    20 +75°
    15 +75°
    -- Coolant By-Pass Nut
    25
    18
    -- Coolant Inlet Housing Bolt
    25
    18
    -- Coolant Outlet Bolt
    27
    20
    -- Coolant Pump Bolt
    11
    97 Coolant Pump Pulley Bolt
    25
    18
    -- Crankshaft Balancer Mounting Bolt
    107
    79
    -- Crankshaft Main Bearing Cap Bolt
    50+75°
    37+75°
    -- Crankshaft Main Bearing Cap Stud
    50+75°
    37+75°
    -- Crankshaft Oil Deflector Nut
    25
    18
    -- Crankshaft Pulley-to-Crankshaft Damper Bolt
    60
    44
    -- Crankshaft Position Sensor Bolt-Front of
    Engine
    8
    71 Crankshaft Position Sensor Bolt-Side of Engine
    8
    71 Crankshaft Position Sensor Harness Retaining
    Bracket Bolt
    5
    45 Cylinder Head Bolt
    60 +90°
    44 +90°
    -- Drive Belt Tensioner Bolt
    50
    37
    -- EGR Valve Adapter Brace Nut
    25
    18
    -- EGR Valve Adapter Stud
    10
    89 EGR Tube Assembly
    25
    18
    -- EGR Valve Assembly Nut
    25
    18
    -- Electronic Ignition Control Module Assemble
    Bolt/Stud
    25
    18
    -- Electronic Ignition Control Assembly Nut
    25
    18
    -- Engine Block Coolant Drain Plug
    19
    14
    -- Engine Block Oil Gallery Plug-Center Rear
    16
    12
    -- Engine Block Oil Gallery Plug-Rear
    33
    24
    -- Engine Block Oil Gallery Plug-Side of Block
    19
    14
    -- Engine Coolant Temperature Sensor
    18
    13
    -- Engine Motor Mount Frame Nut-Engine Left Side
    43
    32
    -- Engine Motor Mount Bracket Nut-Engine Left
    Side
    43
    32
    -- Engine Motor Mount Frame Nut-Engine Right Side
    43
    32
    -- Engine Motor Mount Bracket Nut-Engine Right
    Side
    47
    35
    -- Engine Motor Mount Bracket -Front of Block
    Bolt-Engine Left Side
    103
    76
    -- Engine Motor Mount Bracket-Side of Block
    Bolts-Engine Left Side
    58
    43
    -- Engine Motor Mount Bracket-Front of Block
    Bolts-Engine Right Side
    102
    75
    Bolt-Engine Right Side
    58
    43
    -- Engine Motor Mount Bracket-Transaxle
    75
    55
    -- Engine Mount Strut Bracket Bolt
    80
    59
    -- Engine Oil Cooler Connector
    40
    30
    -- Engine Oil Level Sensor
    22
    16
    -- Evaporator Emission Canister Purge Solenoid
    Mounting Bracket Bolt
    10
    89 Exhaust Manifold Crossover Stud
    9
    80 Exhaust Manifold Nut
    13
    116 Exhaust Manifold Stud
    17
    13
    -- Flywheel Bolt
    82
    60
    -- Front Cover Coolant Drain Plug
    25
    18
    -- Front Cover Bolts- Large
    47
    35
    -- Front Cover Bolts - Small
    27
    20
    -- Front Cover-to-Front Engine Lift Hook Bolt
    25
    18
    -- Front Engine Lift Hook-to-Right Camshaft
    Carrier Bolt
    50
    37
    -- Front Engine Lift Hook-to-Right Cylinder Head
    Bolt (Access through Front Cover)
    50
    37
    -- Fuel Pipe Clip Bolt
    7
    62 Fuel Pipe Retainer Screw
    3
    27 Fuel Rail Assembly Bolt
    10
    89 Ignition Coil Bolt
    25
    18
    -- Ignition Coil Nut
    25
    18
    -- Intermediate Drive Shaft Retainer Screw
    10
    89 Intermediate Shaft Belt Sprocket Bolt
    130
    96
    -- Knock Sensor
    21
    15
    -- Lower Intake Manifold Mounting Bolt
    13
    116 Manifold Absolute Pressure Sensor Bracket Bolt
    8
    71 Oil Cooler Connector
    40
    30
    -- Oil Cooler Hose Fitting
    25
    18
    -- Oil Distribution Cover Bolt
    27
    20
    -- Oil Filter
    16
    12
    -- Oil Filter Fitting
    67
    49
    -- Oil Level Indicator Bolt
    10
    89 Oil Pan Bolt-Except Rear
    11
    97 Oil Pan Bolt-Rear (2)
    27
    20
    -- Oil Pan Drain Plug
    25
    18
    -- Oil Pan Nut
    11
    97 Oil Pan Stud-to-Cylinder Block
    10
    89 Oil Pressure Switch
    32
    24
    -- Oil Pump Cover Bolt
    10
    89 Oil Pump Drive Clamp Bolt
    36
    27
    -- Oil Pump-to-Rear Main Cap Bolt
    54
    40
    -- Power Brake Booster Vacuum Pipe Fitting
    18
    13
    -- Rear Engine Mount Strut Bracket Bolt
    82
    60
    -- Secondary Air Injection Pipe
    25
    18
    -- Secondary Air Injection Pipe Nut-Left Side
    25
    18
    -- Secondary Air Injection Pipe Support Bolt
    10
    89 Secondary Air Injection Pipe Nut-Right Side
    10
    89 Serpentine Drive belt tensioner bolt
    50
    37
    -- Spark Plug
    20
    15
    -- Throttle Body Adapter Bolt
    25
    18
    -- Throttle Body Adapter Nut
    25
    18
    -- Throttle Body Heater Outlet Hose Nipple
    18
    13
    -- Throttle Body Stud
    4
    36 Throttle Body Bolt
    10
    89 Tie Bar Bracket
    26
    19
    -- Timing Belt Cover Bolt
    10
    89 Timing Belt Idler Pulley Bolt
    50
    37
    -- Timing Belt Tensioner Actuator Bracket Bolt
    50
    37
    -- Timing Belt Tensioner Actuator Pulley Pivot
    Bolt
    50
    37
    -- Timing Belt Tenisoner Actuator Side Plate Bolt
    27
    20
    -- Timing Chain Tensioner Bolt
    27
    20
    -- Engine Mount Strut and Engine Lift Bracket
    Bolt
    70
    52
    -- Upper Intake Manifold Retaining Bolt
    26
    19
    -- Water Inlet Fitting to Front Cover
    27
    20
    -- Vacuum Source Manifold Mounting Bolt
    7
    62
