3.6L (VVT) Engine Specifications
    • 9181
    3.6L (VVT) Engine Mechanical Specifications
    Application
    Specification
    Metric English General
    • Engine Type
    V-6
    • Displacement
    3.6 Liter 217 cu in
    • RPO
    LY7
    • VIN
    7
    • Bore
    94 mm 3.7008 in
    • Stroke
    85.6 mm 3.37 in
    • Compression Ratio
    10.2:1
    • Cranking RPM - at 40° C (104°F)
    80 RPM
    • Idle Speed
    600 A/C
    Off - 700 A/C On
    • Firing Order
    1-2-3-4-5-6
    • Spark Plug Gap
    1.1 mm 0.0433 in Block
    • Crankshaft Main Bearing Bore Diameter
    72.867-72.881 mm 2.8688-2.8693 in
    • Cylinder Bore Diameter
    93.992-94.008 mm 3.7005-3.7011 in
    • Cylinder Bore Out-of-Round - Production Max.
    0.013 mm 0.0005 in Camshaft
    • Camshaft Bearing Inside Diameter - Front Number 1
    35.000-35.020 mm 1.3779-1.3787 in
    • Camshaft Bearing Inside Diameter - Middle and Rear
      Number 2-4
    27.000-27.020 mm 1.0630-1.0638 in
    • Camshaft End Play
    0.045-0.215 mm 0.0018-0.0085 in
    • Camshaft Journal Diameter - Front Number 1
    34.936-34.960 mm 1.3754-1.3764 in
    • Camshaft Journal Diameter - Middle and Rear
      Number 2-4
    26.936-26.960 mm 1.0605-1.0614 in
    • Camshaft Journal Out-of-Round
    0.006 mm 0.0002 in
    • Camshaft Journal to Bore Clearance
    0.040-0.084 mm 0.0016-0.0033 in
    • Camshaft Lobe Duration - Exhaust @ 0.150 mm
      (0.0059 in) Lift
    238 degrees
    • Camshaft Lobe Duration - Intake @ 0.150 mm
      (0.0059 in) Lift
    237 degrees
    • Camshaft Lobe Lift - Exhaust
    42.425-42.725 mm 1.6703-1.6821 in
    • Camshaft Lobe Lift - Intake
    42.385-42.685 mm 1.6687-1.6805 in
    • Camshaft Lobe Overlap @ 0.150 mm (0.0059 in) Lift
    0 degrees
    • Camshaft Runout - Front and Rear Number 1 and 4
    0.025 mm 0.0010 in
    • Camshaft Runout - Middle 2 and 3
    0.050 mm 0.0020 in
    • Camshaft Timing @ 0.15 mm (0.0059 in) Lift
    • Valve Opens - Exhaust
    -229 degrees BTDC
    • Valve Opens - Intake
    14 degrees
    ATDC
    • Centerline - Exhaust
    111 degrees ATDC
    • Centerline - Intake
    132 degrees ATDC
    • Valve Closes - Exhaust
    9 degrees
    ATDC
    • Valve Closes - Intake
    251 degrees ATDC
    • Valve Lift - Exhaust
    10.8 mm 0.4252 in
    • Valve Lift - Intake
    10.8 mm 0.4252 in Cooling
    System
    • Thermostat Full Open Temperature
    95°C 203°F Connecting
    Rod
    • Connecting Rod Bearing Clearance
    0.010-0.070 mm 0.0004-0.0028 in
    • Connecting Rod Bore Diameter - Bearing End
    59.620-59.636 mm 2.3472-2.3479 in
    • Connecting Rod Bore Diameter - Pin End
    24.007-24.021 mm 0.9452-0.9457 in
    • Connecting Rod Length - Center to Center
    150.400 mm 5.9212 in
    • Connecting Rod Side Clearance
    0.095-0.355 mm 0.0374-0.0140 in
    • Connecting Rod Width - Bearing End
    • Production
    21.775 mm 0.8573 in
    • Service
    21.725-21.825 mm 0.8553-0.8593 in
    • Connecting Rod Width - Pin End
    • Production
    21.775 mm 0.8573 in
    • Service
    21.725-21.825 mm 0.8553-0.8593 in Crankshaft
    • Connecting Rod Journal Diameter
    55.992-56.008 mm 2.2044-2.2050 in
    • Connecting Rod Journal Out-of-Round
    0.005 mm 0.0002 in
    • Connecting Rod Journal Taper
    0.005 mm 0.0002 in
    • Connecting Rod Journal Width
    • Production
    22.000 mm 0.8661 in
    • Service
    21.920-22.080 mm 0.8630-0.8693 in
    • Crankshaft End Play
    0.100-0.330 mm 0.0039-0.0130 in
    • Crankshaft Main Bearing Clearance
    0.010-0.060 mm 0.0004-0.0024 in
    • Crankshaft Main Journal Diameter
    67.992-68.008 mm 2.6768-2.6775 in
    • Crankshaft Main Journal Out-of-Round
    0.005 mm 0.0002 in
    • Crankshaft Main Journal Taper
    0.005 mm 0.0002 in
    • Crankshaft Main Journal Thrust Wall
    • Runout
    0.000-0.040 mm 0.0000-0.0016 in
    • Square
    0.000-0.010 mm 0.0000-0.0004 in
    • Crankshaft Main Journal Width, #2, 4
    • Production
    24.000 mm 0.9449 in
    • Service
    23.900-24.100 mm 0.9409-0.9488 in
    • Crankshaft Main Journal Width, #3
    • Production
    24.400 mm 0.9606 in
    • Service
    24.360-24.440 mm 0.9591-0.9622 in
    • Crankshaft Pilot Bearing Bore Diameter
    20.965-20.995 mm 0.8254-0.8266 in
    • Crankshaft Rear Flange Runout
    0.025 mm 0.0010 in
    • Crankshaft Reluctor Ring Runout - Maximum
    1.500 mm 0.0591 in
    • Crankshaft Runout
    0.030 mm 0.0012 in
    • Crankshaft Thrust Bearing Clearance
    0.076-0.305 mm 0.0030-0.0120 in
    • Crankshaft Thrust Surface - Height Diameter
    95.000 mm 3.7401 in
    • Crankshaft Thrust Surface Runout
    0.040 mm 0.0016 in Cylinder
    Head
    • Combustion Chamber Volume
    53.407 cc 3.259 cu in
    • Valve Guide Bore - Exhaust
    6.000-6.020 mm 0.2362-0.2370 in
    • Valve Guide Bore - Intake
    • Valve Guide Installed Height
    14.050-14.550 mm 0.5531-0.5728 in
    • Valve Lifter Bore Diameter
    12.008-12.030 mm 0.4728-0.4736 in Lubrication
    System
    • Oil Capacity - with Filter
    5.68 Liters 6 Quarts
    • Oil Capacity - without Filter
    5.20 Liters 5.5 Quarts
    • Oil Pressure - Minimum @ Idle
    69 kPa 10 psi
    • Oil Pressure - Minimum @ 2,000 RPM
    138 kPa 20 psi
    • Piston Cooling Jet Valve Opening Pressure
    1.7-2.3 bar 25-33 psi Oil Pump
    • Gear Diameter - Outer
    87.095-87.175 mm 3.4289-3.4321 in
    • Gear Pocket - Depth
    15.565-15.600 mm 0.6128-0.6142 in
    • Gear Pocket - Diameter
    87.275-87.325 mm 3.4360-3.4380 in
    • Gear Thickness - Drive/Driven
    15.511-15.536 mm 0.6107-0.6117 in
    • Gear-to-Cover Clearance - Drive/Driven
    0.030-0.085 mm 0.0012-0.0033 in
    • Gear-to-Housing Clearance - Drive/Driven
    0.100-0.230 mm 0.0039-0.0091 in
    • Inner Gear Tip Clearance
    0.075-0.180 mm 0.0030-0.0071 in
    • Crankshaft Clearance to Housing
    0.040-0.130 mm 0.0016-0.0051 in
    • Inner Gerotor Hub Diameter
    53.310-53.335 mm 2.0988-2.0998 in
    • Housing Hub Diameter
    53.380-53.420 mm 2.1016-2.1031 in
    • Inner Gerotor Hub Clearance to Housing
    0.045-0.110 mm 0.0018-0.0043 in Piston Rings
    • Piston Ring End Gap
    • First Compression Ring
    0.150-0.300 mm 0.0059-0.0118 in
    • Second Compression Ring
    0.280-0.480 mm 0.0110-0.0189 in
    • Oil Control Ring
    0.150-0.600 mm 0.0059-0.0236 in
    • Piston Ring to Groove Clearance
    0.030-0.065 mm 0.0012-0.0026 in
    0.015-0.060 mm 0.0006-0.0024 in
    • Oil Control Ring
    0.030-0.170 mm 0.0012-0.0067 in
    • Piston Ring Thickness
    1.175-1.190 mm 0.0463-0.0469 in
    1.470-1.495 mm 0.0579-0.0589 in
    • Oil Control Ring
    2.360-2.480 mm 0.0929-0.0976 in Pistons and
    Pins
    • Piston
    • Piston Diameter
    93.956-93.974 mm 3.6990-3.6998 in
    • Piston Pin Bore Diameter
    24.004-24.009 mm 0.9450-0.9452 in
    • Piston Ring Groove Width - First Compression Ring
    1.220-1.240 mm 0.0480-0.0488 in
    • Piston Ring Groove Width - Second Compression Ring
    1.510-1.530 mm 0.0595-0.0602 in
    • Piston Ring Groove Width - Oil Control Ring
    2.510-2.530 mm 0.0988-0.0996 in
    • Piston to Bore Clearance
    0.026-0.052 mm 0.0010-0.0021 in
    • Pin
    • Piston Pin Clearance to Connecting Rod Bore
    0.007-0.024 mm 0.0003-0.0010 in
    • Piston Pin Clearance to Piston Pin Bore
    0.004-0.012 mm 0.0002-0.0005 in
    • Piston Pin Diameter
    23.997-24.000 mm 0.9448-0.9449 in
    • Piston Pin Length
    60.600-61.100 mm 2.3858-2.4055 in Valve System
    • Valves
    • Valve Face Angle
    44.25 degrees
    • Valve Face Runout
    0.038 mm 0.0015 in
    • Valve Face Width - Exhaust
    2.750 mm 0.1083 in
    • Valve Face Width - Intake
    2.180 mm 0.0858 in
    • Valve Head Diameter - Exhaust
    30.470-30.730 mm 1.1996-1.2098 in
    • Valve Head Diameter - Intake
    36.830-37.090 mm 1.4500-1.4602 in
    • Valve Installed Height
    35.23-36.69 mm 1.3870-1.4445 in
    • Valve Length - Exhaust
    97.110 mm 3.8232 in
    • Valve Length - Intake
    101.230 mm 3.9854 in
    • Valve Seat Angle - Seating Surface
    45 degrees
    • Valve Seat Angle - Relief Surface
    30 degrees
    • Valve Seat Angle - Undercut Surface
    60 degrees
    • Valve Seat Runout - Maximum
    0.050 mm 0.0020 in
    • Valve Seat Width - Exhaust Seating Surface
    1.400-1.800 mm 0.0551-0.0709 in
    • Valve Seat Width - Exhaust Relief Surface
    0.700-0.900 mm 0.0276-0.0354 in
    • Valve Seat Width - Intake Seating Surface
    1.000-1.400 mm 0.0394-0.0551 in
    • Valve Seat Width - Intake Relief Surface
    0.500-0.700 mm 0.0197-0.0276 in
    • Valve Stem Diameter - Exhaust
    5.945-5.965 mm 0.2341-0.2348 in
    • Valve Stem Diameter - Intake
    5.955-5.975 mm 0.2344-0.2352 in
    • Valve Stem-to-Guide Clearance - Exhaust
    0.035-0.075 mm 0.0014-0.0030 in
    • Valve Stem-to-Guide Clearance - Intake
    0.025-0.065 mm 0.0010-0.0026 in
    • Valve Lifters
    • Valve Lifter Diameter
    11.489-12.000 mm 0.4523-0.4724 in
    • Valve Lifter-to-Bore Clearance
    0.037-0.041 mm 0.0015-0.0016 in
    • Rocker Arms
    • Valve Rocker Arm Ratio
    1.68 to 1
    • Valve Rocker Arm Roller Diameter
    17.750-17.800 mm 0.6988-0.7008 in
    • Valve Springs
    • Valve Spring Coil Thickness
    3.250 x 3.900 mm 0.1280 x 0.1535 in
    • Valve Spring Diameter - Inside Top
    12.090-12.590 mm 0.4760-0.4957 in
    • Valve Spring Diameter - Outside Top
    20.140 mm 0.7929 in
    • Valve Spring Diameter - Inside Bottom
    17.950-18.450 mm 0.7067-0.7264 in
    • Valve Spring Diameter - Outside Bottom
    26.000 mm 1.0236 in
    • Valve Spring Free Length
    42.050-44.850 mm 1.6555-1.7657 in
    • Valve Spring Installed Height - Closed
    35.000 mm 1.3779 in
    • Valve Spring Installed Height - Open
    24.000 mm 0.9449 in
    • Valve Spring Load - Closed
    247-273 N 56-61 lb
    • Valve Spring Load - Open
    598-662 N 134-149 lb
    • Valve Spring Total Number of Coils
    7.1 Fastener Tightening Specifications
    Application
    Specification
    Metric English A/C
    • Compressor Bolt - Front
    50 N·m 37 lb ft
    • Compressor Bolt - Rear
    22 N·m 17 lb ft
    • Compressor Bracket Bolt - Front
    50 N·m 37 lb ft
    • Compressor Hose Assembly Bolt
    9 N·m 80 lb in Camshaft
    Position Actuator
    • Camshaft Bolt
    58 N·m 43 lb ft
    • Oil Control Valve Bolt
    10 N·m 89 lb in Camshaft Cap Bolt 10 N·m 89 lb in Camshaft Cover Bolt 10 N·m 89 lb in Camshaft Cover Bolt 10 N·m 89 lb in Camshaft Intermediate
    Drive Sprocket Bolt - Idler Sprocket
    58 N·m 43 lb ft Camshaft Position Sensor
    Bolt
    10 N·m 89 lb in Catalytic Converter
    • Exhaust Manifold Nut
    50 N·m 37 lb ft Close Out Cover Bolt 10 N·m 89 lb in Clutch Pressure Plate Bolts 23 N·m 17 lb ft Connecting
    Rod Bolt
    • First Pass
    30 N·m 22 lb ft
    • Second Pass - Counter Clockwise
    Back Off
    to Zero
    • Third Pass
    25 N·m 18 lb ft
    • Final Pass
    110 Degrees
    Coolant Outlet Bolt 10 N·m 89 lb in Crankshaft
    Balancer Bolt
    • First Pass
    100 N·m 74 lb ft
    • Final Pass
    150 Degrees
    Bolt
    Inner
    • First Pass
    20 N·m 15 lb ft
    • Final Pass
    80 degrees Outer
    • First Pass
    15 N·m 10 lb ft
    • Final Pass
    110 Degrees
    Side
    • First Pass
    30 N·m 22 lb ft
    • Final Pass
    60 Degrees Crankshaft Position Sensor Bolt 10 N·m 89 lb in Crankshaft Rear Oil Seal Housing Bolt 10 N·m 89 lb in Cylinder
    Head Bolt - M8
    • First Pass
    15 N·m 10 lb ft
    • Final Pass
    60 Degrees Cylinder
    Head Bolt - M11
    • First Pass
    45 N·m 33 lb ft
    • Final Pass
    120 degrees
    Cylinder Head Core Hole Plug 31 N·m 23 lb ft Drive Belt
    • Idler Pulley Bolt
    50 N·m 37 lb ft
    • Tensioner Bolt
    50 N·m 37 lb ft ECM
    • Bolt
    10 N·m 89 lb in
    • Bracket Bolt - Front
    23 N·m 17 lb ft
    • Bracket Bolt - Side
    10 N·m 89 lb in
    • Grounding Bolt
    4.5 N·m 40 lb in ECT Sensor 22 N·m 16 lb ft Engine
    Flywheel Bolt
    • First Pass
    30 N·m 22 lb ft
    • Final Pass
    45 Degrees Engine Front Cover Bolt 23 N·m 17 lb ft Engine Mount
    • Bracket Bolt to Engine Block - M8
    38 N·m 28 lb ft
    • Bracket Bolt to Engine Block - M10
    60 N·m 45 lb ft
    • Nut to Engine Mount Bracket
    80 N·m 59 lb ft
    • Nut to Frame
    80 N·m 59 lb ft EVAP Purge Valve Bolt 10 N·m 89 lb in Engine Wiring Harness
    Bracket
    • Bolt - Cylinder Head Rear
    40 N·m 30 lb ft
    • Bolt - ECM Bracket Side
    23 N·m 17 lb ft
    • Bolt - ECM Bracket Top
    10 N·m 89 lb in
    • Bolt - Left Side Oil Filter Adapter
    10 N·m 89 lb in
    • Bolt - Left Side Oil Pan
    10 N·m 89 lb in
    • Bolt - Near Crankshaft Position Sensor
    50 N·m 37 lb ft
    • Bolt - Right Side Block Front
    23 N·m 17 lb ft
    • Bolt - Right Side Head Front
    Ground
    10 N·m 89 lb in
    • Bolt - Left Cylinder Head Side
    10 N·m 89 lb in
    • Bolt - Right Cylinder Head Rear
    10 N·m 89 lb in Exhaust Manifold
    • Bolt
    20 N·m 15 lb ft
    • Heat Shield Bolt
    10 N·m 89 lb in Fuel Rail Bolt 10 N·m 89 lb in Generator
    • Bolt
    50 N·m 37 lb ft
    50 N·m 37 lb ft
    22 N·m 16 lb ft
    • Cable Nut
    13 N·m 115 lb in Ground Cable Bolt 50 N·m 37 lb ft Heater Inlet/Outlet Pipe Assembly
    Bolt
    10 N·m 89 lb in Ignition Coil Bolt 10 N·m 89 lb in Intake Manifold
    • Brace Bolt - Engine Front Cover M12
    65 N·m 48 lb ft
    • Brace Bolt/Ball Stud - Intake Manifold M6
    10 N·m 89 lb in
    • Sight Shield Ball Stud
    9 N·m 80 lb in
    • Tuning Valve Bolt
    10 N·m 89 lb in
    • Upper-to-Cylinder Head Bolt - Long
    23 N·m 17 lb ft
    • Upper-to-Cylinder Head Bolt - Short
    23 N·m 17 lb ft
    • Upper-to-Lower Intake Manifold Bolt
    23 N·m 17 lb ft Knock Sensor Bolt 23 N·m 17 lb ft MAP Sensor Bolt 10 N·m 89 lb in Oil Drain Plug 25 N·m 18 lb ft Oil Filter Cap 25 N·m 18 lb ft Oil Filter Housing
    Adapter
    • Bolt - Cylinder Head M10
    65 N·m 48 lb ft
    • Bolt - Engine Block M8
    23 N·m 17 lb ft Oil Gallery Plug 31 N·m 23 lb ft Oil Level Indicator Tube Bolt 10 N·m 89 lb in Oil Level Sensor Bolt 10 N·m 89 lb in Oil Pan
    • Bolt - Block M8
    23 N·m 17 lb ft
    • Bolt - Crankshaft Rear Oil Seal Housing M6
    10 N·m 89 lb in
    • Windage Tray Bolt
    10 N·m 89 lb in Oil Pressure Sender 20 N·m 15 lb ft Oil Pump
    • Bolt
    23 N·m 17 lb ft
    • Cover Bolt
    13 N·m 115 lb in Oxygen Sensor
    • Pump Converter Pipe
    40 N·m 30 lb ft PCV Tube Bracket Bolt 10 N·m 89 lb in Piston Oil Cooling Nozzle Bolt 10 N·m 89 lb in Power Steering Pump
    • Bracket to Engine Bolt
    50 N·m 37 lb ft
    • Pump to Bracket Bolt
    22 N·m 16 lb ft
    • Reservoir Bolt - Lower
    25 N·m 18 lb ft
    • Reservoir Bolt - Upper
    9 N·m 80 lb in Primary Camshaft Drive
    Chain
    • Left Guide Bolt - Oil Pump
    13 N·m 115 lb in
    • Tensioner Bolt
    23 N·m 17 lb ft
    • Upper Guide Bolt
    23 N·m 17 lb ft Radiator Outlet Pipe
    • Bolt - Generator Bracket
    23 N·m 17 lb ft
    50 N·m 37 lb ft
    • Bolt - Thermostat Housing
    23 N·m 17 lb ft Secondary Camshaft Drive
    Chain
    • Guide Bolt
    23 N·m 17 lb ft
    • Shoe Bolt
    23 N·m 17 lb ft
    • Tensioner Bolt
    23 N·m 17 lb ft Spark Plug 18 N·m 13 lb ft Starter Motor
    • Bolt
    50 N·m 37 lb ft
    • Cable Nut
    13 N·m 115 lb in Suction Tube Bolt 10 N·m 89 lb in Suction Screen Bolt 10 N·m 89 lb in Thermostat Housing Bolt 10 N·m 89 lb in Throttle Body Bolt 10 N·m 89 lb in Torque Converter Bolt 60 N·m 44 lb ft Transmission
    • Mount Bolt to Transmission - RPO M82
    60 N·m 45 lb ft
    • Range Selector Lever Nut
    9.5 N·m 84 lb in
    • To Engine Bolt
    50 N·m 37 lb ft Water Pump
    • Bolt
    10 N·m 89 lb in
    • Pulley Bolt
    10 N·m 89 lb in
