Pistons
    • 9189
    Pistons
    A new page entry has been added:
    [drupal=141]Pistons[/drupal]
    Role
    As one of the major moving parts in the power-transmitting assembly, the piston must be so designed that it can withstand the extreme heat and pressure of combustion. Pistons must also be light enough to keep inertial loads on related parts to a minimum. The piston aids in sealing the cylinder to prevent the escape of combustion gases. It also transmits some of the heat through the piston rings to the cylinder wall.
    Types
    Cast
