what do you guys use for them????
HELP 6/60 engine stand bolts!!!!
What he said. I just took one of the bellhousing bolts and one of the stands arms to Home Depot and Lowes until I found some that fit.
I got the BIG engine stand so it needed longer bolts than a normal stand.Taylor
1998 Lincoln Mark VIII
i went to lowes as well but my bellhousing bolt was m12 1.5 but they only had 4 inch bolts. which is the length of the engine stand bracket, i need at least 5.5 inch or better.
lowes did not have any for me. anywhere else i can go? home depot doesn't even carry metric bolts.The Official Rotating Mass Nazi
i got mine from a local bolt company.. 12mm x 1.75 pitch. around 3" long or so... they worked perfect.
+1 on the bolt company. Locally we have a place called "Broward Bolt and Fastner" most areas have one. If you can find an ACE (or mom and pop) hardware, they usually will have a better selection.
