HELP 6/60 engine stand bolts!!!!
  • dohcfiend
    King Chalupa
    • Jan 2004
    • 2351
    what do you guys use for them????
    • 9191
    http://www.60degreev6.com/showthread...ne+stand+bolts
    • 3100 MPFI
      • 1522
      What he said. I just took one of the bellhousing bolts and one of the stands arms to Home Depot and Lowes until I found some that fit.
      I got the BIG engine stand so it needed longer bolts than a normal stand.
      Taylor
      1998 Lincoln Mark VIII
      • dohcfiend
        King Chalupa
        • Jan 2004
        • 2351
        i went to lowes as well but my bellhousing bolt was m12 1.5 but they only had 4 inch bolts. which is the length of the engine stand bracket, i need at least 5.5 inch or better.
        lowes did not have any for me. anywhere else i can go? home depot doesn't even carry metric bolts.
          i got mine from a local bolt company.. 12mm x 1.75 pitch. around 3" long or so... they worked perfect.
            Live life 3.7mi at a time
            • 4555
            +1 on the bolt company. Locally we have a place called "Broward Bolt and Fastner" most areas have one. If you can find an ACE (or mom and pop) hardware, they usually will have a better selection.
