Anyone ever decide if the 75mm Northstar TB would fit on that?
3500 Plenum TB Adapter
Anyone ever decide if the 75mm Northstar TB would fit on that?SpudFiles
Theopia
Enjoy life online.
3500 swap, 60degreeV6 1393 Cam, Ported Intakes, Comp Cams Valve Springs, 65mm TB, Custom Pushrods, S&S Headers, 97 PCM with DHP Powrtuner, 2.5" back to dual Hooker Aerochambers, SS Brake Lines, Addco swaybar, KYB's, Intrax Springs, STB's, etc!Tags: None
well the hole is 65mm, so im guessing IF it even bolted on you would need to make the hole bigger, which would get rid of the o ring too...
why do you want one that big?sigpic
Price. $100 on that vs $375 and a wait till at least June for the CNC'ed 65mm.SpudFiles
Theopia
Enjoy life online.
TB + Adapter
Plus after modifications I would like the 75mm. The 65mm is sweet but I gotta count my dollars for this swap.SpudFiles
Theopia
Enjoy life online.
Don't want to change the subject, but a 3500 plenum can be ported to 75mm? Will the 3500 plenum bolt to a late 3400 lower?
Not trying to jack a thread, but I have a 75mm TB and the 3400 upper is too small in the neck to port to 75mm. I don't want to restrict it at all by "tapering" it, so a custom plenum was the plan (unless the 3500 is a better/easier option).
and not to mention sometimes to much can also hurt especially when u may not have the horsepower or the motor to require this size of tb94 BerrettaZ26 3400,5 spd, aluminum flywheel, stg3+ spec clutch, poly mounts everywhere, strut and strut to rad braces, s&s headers, euro mirrors, and taillights, E36 headlights, blk widow spoiler, GTU rimz, intrax, KYB, OBD2 swap rear disk swap with ss lines and ss clutch line, addco rear bar
