Double Roller Timing Chain for Roller Cams
damn. i gotta get one but i dont have time for this build
guess when my current chain streches im gonna upgrade
yeah, i just cant wait any longer to get my car back together. i will probly swap it out at 10k or winter, whichever comes firstsigpic
Would one assume that ANY boosted application should consider this as an ingrual part of a HP build? And Ben for the novice builder you might want to explain the uses of the ability to set the timing at the gear............because I would love an explaination of that aswell............great job guys I am sure it will do well in the store..............
Boosted I wouldnt imagine it would "help" so much. If you are using some heavy valve springs and or a high lift cam its definitely some good insurance versus praying your stock chain wont stretch and put a valve through some expensive pistons.Originally posted by zofo61 View PostWould one assume that ANY boosted application should consider this as an ingrual part of a HP build? And Ben for the novice builder you might want to explain the uses of the ability to set the timing at the gear............because I would love an explaination of that aswell............great job guys I am sure it will do well in the store..............
Im not too wise on the subject of being able to advance or retard the timing with the cam either. If someone could do some further explination that would be awesome.2006 AWD TBSS 12.538 @ 106.92 1.66 60' Bolt-ons only
Ill go into more detail with it using my simulation software as examples, but advancing the timing effectively lowers your powerband. Say you make power from 2500-6500. 3 degrees might be 2200-6200.
Its not just a powerband shift as it is a total hp change, as you can tune the timing for a specific setup and increase output while changing the powerband.
Roller timing chains have less friction, so aside from strength and cam timing options, you also increase power from the part itself.Ben
So given that....if the right cam profile was to be designed with my kit in mind...then the timing option with this set would give me a better starting point to tune from? Given my(and Phils)for example........what would be the option used with a CSC specific cam profile.....?....or does that just give you more options when dialing in the desktop dyno?
Ben, what's your recommendation on the double roller for the regrinds from the store? Do you guage double-roller necessity on lobe lift amounts? Duration? A combination of the two?Matt
Yikes, I'll stick to the pre 99 setups until I find out I'm stretching them like its going out of style..Originally posted by silvergtjrad View PostCrank, timing cover, possibly the block and oil plugs.
Yea, that may not be a bad Idea. I just want to do everything I can while the motor is all apart. Ive only got one car, so if anything breaks, Ive got no other wheels to get around town. Hell, Ive dropped enough money on this car anyways, so why not!Originally posted by 3400-95-Modified View PostYikes, I'll stick to the pre 99 setups until I find out I'm stretching them like its going out of style..2006 AWD TBSS 12.538 @ 106.92 1.66 60' Bolt-ons only
I'm wondering....as close as things are in there with the DR, was crankshaft end play taken into account as well as possible future wear on the thrust bearing?Andy
fastest 1/8: 10.19@ 67.17
fastest 1/4: 16.16@ 82.70
