They were 4 layers for a .060 set, three were stamped, two back to back, then the thick and one more stamped one... I do not know what the thicknesses were.
Cometic Head Gaskets $139.99
Thanks. That is really good if they had 3 embossed layers. That means they were designed for performance. 4 would be better (that is what the LS9 has), but sometimes that is not possible due to design constraints.
Now I am just wondering now how high the stopper is (or if it has one). That would most likely be on the only layer without embossed beads (the thick center layer) between where the embossed combustion bead sits and the bore. I assume the bore opening is probably around 95 or 96 mm to work on the newest LX9's, LA1's, LG8's, etc.
Bore opening would be whatever you wanted it to be, stock 3500 was 3.720 and you can go up to .060 over, I checked...
There was no question in my mind that these were made for performance or not... Cometic is a VERY reputable company... It just sucks that this first run was not biased on the right gasket and that just put their completion of the fix too far after when I needed them. Otherwise I would have definitely used them.
I don't think these had a stopper bead from what I'm reading about what one is. I do not remember seeing something like that, but I could be wrong.
The stopper puts pretention in the head around the bore. Think of it as a transfer of the bolt load directly to the area that needs the highest sealing - the bore. It also acts as a compression limiter so the beads are not crushed flat. That limits their spring recovery long-term. Otherwise, you will develop fatigue cracks in the beads over time which cause leaks.
That's the secret to MLS gaskets - the embossment beads act as springs. Your cylinder pressure is balanced against your bolt loads. The more cylinder pressure you have, the less your bolts hold clamp and the more your head lifts. MLS beads spring to seal that dynamic vertical lift. Old graphite and composite designs had significantly less ability to do this. All new designs are MLS for this reason.
The stopper is a flat piece of steel near the bore on the flat layer about 1 mm wide. Without it, the overall CHG design is much weaker.
Any updates about the gaskets?1999 Grand Am SC/T - 301HP, 365TQ - ARP Rod Bolts, ARP Oil Pan Bolts, ARP Head Studs, Mild Cam, 3500 Heads w/28696 Springs, Ported 3500 LIM & 3400 UIM, GT32R @ 12PSI, Rebuilt Trans, 42.5 Injectors, Racetronix Fuel Pump, TCE Adjustable FPR, SC/T Kit, SC/T Spoiler, Shaved Trunk, WOT-Tech Coil Overs, Solid Rear Laterals w/Poly Bushings, Control Arms w/Poly Bushings, Poly Engine & Trans Mounts, Front & Rear Strut Braces
Since the ETA was 3-5 weeks, what happens after 5 weeks (next week) if the gaskets aren't done?1999 Grand Am SC/T - 301HP, 365TQ - ARP Rod Bolts, ARP Oil Pan Bolts, ARP Head Studs, Mild Cam, 3500 Heads w/28696 Springs, Ported 3500 LIM & 3400 UIM, GT32R @ 12PSI, Rebuilt Trans, 42.5 Injectors, Racetronix Fuel Pump, TCE Adjustable FPR, SC/T Kit, SC/T Spoiler, Shaved Trunk, WOT-Tech Coil Overs, Solid Rear Laterals w/Poly Bushings, Control Arms w/Poly Bushings, Poly Engine & Trans Mounts, Front & Rear Strut Braces
like late parts have discouraged the roller rocker fanatics?Originally posted by SappySE107 View PostPeople will be more upset than they are now?
I ended up going with the stock gaskets which allowed me to finish my motor, but unfortunately I inverted two retaining clips in my trans which locked the input clutch and killed it... so I'm still on jackstands... LOL Hopefully their ETA is only a week out because they are passed their 5 week max if I did my math right. How many people are waiting on these to get a project done?
kinda glad i held off on these till this coming winter.sigpic
99 Grand Am GT
1357 cam 227 233 .050 dur 515 515 lift 112 lsa
