Any chance of getting some made for the 3900?
3900 phenolic spacer?
I think alot of ppl would be interested in these spacers again.. @ least the 3400 and 3500Stage 2 Comp WOT-TECH heads, upper and lower intake P&P, street/strip cam, Custom pushrods, TCE LS Lifter Springs, Dimond Pistons 10.7:1, 65mm TB, stage 3 custom cold air intake, heat shield(only for Heat protection on Temp and MAF sensor), DHP Tuner, Adj FPR, #28 injectors, MSD ign coils, talyor wires, S&S header, S&S high flow cat, borla cat Back, all ARP studs, TCE double timing chain with crank kits, Cometic head gaskets, A/C deleted, HF water pump, and so on
Less than you'd think. the idea is cool but in reality they don't make much difference at all.Originally posted by ShieldsM View PostI think alot of ppl would be interested in these spacers again.. @ least the 3400 and 3500
An aluminum version with nitrous nozzle holes would be sweet though.
direct port without the workOriginally posted by Superdave View PostAn aluminum version with nitrous nozzle holes would be sweet though.
I should do that with the ITB's.. muahahahahaha.......Originally posted by robertisaar View Postdirect port without the work
