Do anyone think we have a large enough demand for these? Something that will clear a 5sp or a 4t60e on a W-body?
3100 Headers?
RE: 3100 Headers?
Nope. Considering that was the people involved in getting S&S to make them, and then they made them for the GAGT instead. You will never get a company (unless its a small shop like Ben's) to make headers for a car that is over a couple years old. Custom is pretty much the only way to go...-Brad-
We almost had headers for the 94-98 V6 N-bodies made by milzymotorsports.com and the only reason they weren't made was because the owner of the donor car fell off the face of the planet when we were ready for him.
Milzy also has a similar program for 3100/3400 95-99 Monte Carlo's which I think are the same or similar body.1995 Grand Am SE
Ok, i don't need milzy in my store section:P Once I have the header flanges made up and can stock up on tubing and bends, I will be more than happy to start working on headers for the different 60V6 applications. I may even end up doing the prototype, and then having someone else produce them for me depending on the amount of demand and time. I don't have space to store a ton of headers nor the time to really bust out multiple sets as I am solo doing everything, hence the outsourcing where I can
I will tell you this. Any headers I produce initially will not be "long tube, equal length". I will try to keep them equal, and I will definetly use a collector, but ease of install is really what sells headers (plus the lower price). Any tuned headers I make will require other modifications to the engine bay and maybe firewall. So basically, I want to offer different headers for the same application based on price and ease of install. What car I start with is up to everyone else. I will be doing the DOHC headers first obviously as that is what my car is, but after that, anything goes.Ben
i have a 94 N-body w/2002 3100 that could be used for donor in/around fort wayne,IN. i have two cars now, but g/f drives it for work. as long as she can get back and forth to work, i don't mind it being used.1994 Oldsmobile Achieva (2002 3100 SFI)
Homemade ram-effect CAI
K&N cylinder filter
Poorboy Lowering Kit
Front STB
A nice set of headers for an 3.1L AT beretta that don't cost $900 would be nice
98 camaro swapping in lz9 th400 setup
LZ9 specs: (Subject to Change work in progress)
4.0L(after bore 3.917 and stroke 3.3485),carrillo sbc rods(narrowed),wiseco custom forged pistons 8.5:1 CR, TCE Double Roller timing chain, gen 3 cam, P&P heads, headers 1 3/4 primaries into 3-1 collector, and going to run ms2.
Good thing too, because he'd loose his car for about a month +Originally posted by blackbombshell95yes. but his donor fell through
yep, heders for a 3400 94 Z24 would be great too!
Andy
fastest 1/8: 10.19@ 67.17
fastest 1/4: 16.16@ 82.70
it's so easy to make your own tho.Originally posted by torq455yep, heders for a 3400 94 Z24 would be great too!
i'll post pics of mine once i pick up the other 3400 on Monday.
i used an old set of headers from my Trans Am and a few pieces from S&S, and some flanges i picked up on Ebay. :P
