Hey, I was wondering if anyone knows of anyone who has had a pre oiler kit. Does any body know about these kits. They are supposed to reduce bearing wear by like 60% or something like that.
Basically they bring the oil pressure up before you start cranking, so you don't start dry. There are different types though. Ones with a electric motor that drives an auxilary oil pump. Or the other kind has a tank that holds the oil pressure from the time you last ran your car, then releases it when you turn your ignition on.
Any info, I'm thinking about adding one to my car when I rebuild.
Lyle
Lyle
