gmpartsdirect lists a valve spring for the 1997 Monte Carlo 3.4 DOHC. I had this spring tested out and its pure bullshit.
1.400" installed height = 65#
1.030" Max Lift = 155#
Coil Bind recommended by the machine shop was 1.130"!!!
At 1.030 where max lift on stock cams is, the bottom three coils are collapsed and there is only marginal room for the top 2 coils. This means that there is damn little to give after 1.030" and they are close to total coil bind.
Im going to look for another source, as well as see if I can get an answer from GM about this.
