twin cam front cover replacment
  • twin cam front cover replacment
    I just got my new 3.4 DOHC home, and cracked the front timing/front cover. I have a spare one. Can it be replaced without removing the heads or the cams?
    Taylor
    1998 Lincoln Mark VIII
    [IMG]http://i174.photobucket.com/albums/w86/riven2129/newestsig1.jpg[/IMG]
    pics of the damage
    Taylor
      I think you can. I haven't done it but I don't know of anything bolting through the head or cam carrier that you don't get to from the timing chain cover already.
        I talked to Lorenzo and he said I should be able to do it. I will just have to remove the cam sprockets (as well as the other timing components, and harmonic damper).
        I didn't want to open the engine up, but I guess it could be worse. At least I KNOW it runs. Before we pulled it, we drove the car.
        Taylor
          i am working on it now. I don't think I will even need to remove the cam gears.
          It is pretty straightforward. The only issue I am having is with the lower cam sprocket removal. My uncle will bring me a tap set tomorrow, and I will do it then.
          Taylor
            One question, HOW THE FUCK DID THAT HAPPEN???
            [img]http://www.60degreev6.com/files/albums/0/NewWEB-2-2-1.jpg[/img]
            [url]WWW.OverKillEngineeringMotorsports.com[/url]
              I ment just remove the lower cam sprocket
              Lorenzo
                I was lifting it out of the back of a van, but for clearance reasons, I could not use my engine leveler. The lift bracket that it was bolted too twisted, and snapped the cover.
                and I am GLAD this happened. Check out this mess.
                Taylor
                  I got the front cover swapped out today. I didn't get pics of the new cover back on, but I will get pics of that tomorrow.
                  Here is the broken cover. Tomorrow, I think I will piss on it, then throw it in the garbage.
                  This is the new cover gasket. It is THICK instead of being just PAPER like the 3100 one. In this pic, I have it sitting on a 3100 front cover just to see if it can be used on a 3100. Looks okay to me.
                  and how thick it is
                  And here is the engine with the cover off.
                  This is a closeup of the timing chain and tensioner on the 3.4 DOHC. I think that when this is all over with, I will see if the tensioner can be added to a 3100. Seems like a good idea.
                  These are the holes I had to tap into the cam sprocket to use a puller to get it off.
                  I tapped 3 holes, then used a grinding wheel on my dremel to enlarge the slots of my puller so that I didn't have to buy a new puller.
                  That is all for now.
                  Taylor
                    Nice chunk of ALUMINUM...........Which isn't doing to badly in scrap value...
                      yeah. I think when this is all said and done, those 2 bad engines, I am going to keep some choice parts off of them, and then scrap the rest. I need to clear out some of my stock anyways.
                      I think tomorrow, I am going to start pulling the engine out.
                      Taylor
                        Recycle aluminum for cash!
                        [/SIZE]
                          i just might do that.
                          Taylor
                            That's great. That looks exactly like the puller I have and that's exactly what I did to make it work!
                            Tim
                            325 whp 350 lb-ft
                              I talked to Ben and that is what he recommened doing. I think that the next time I have to do this (please God, don't let me EVER have to do this again, but just in case.....) I will use a steering wheel puller that is only 2 bolts. I thought it would be harder to get out, but it was suprising.
                              It is held in with just enough force to make it so you can't remove it by hand or with simple tools.
                              Taylor
