Ok here is what I scanned when I was ideling at a red light
LOAD VALUE- 4.3%
COOLANT TEMP-181 *F
SHORT TERM FUEL TRIM- 6.2%
LONG TERM FUEL TRIM- 16.4%
MAP SENSOR-14 IN.HG
ENGINE RPM- 765
SPEED-0MPH
IGNITION TIMING- ADV -19.5*
INTAKE AIR TEMP- 123*
AIR FLOW RATE- .81 LB/MIN
THROTTLE POSITION- 0%
2ND AIR STATUS ATMOSPHERE- OFF
OXYGEN SENSOR 1 BANK 1- .590V
SHORT TERM FUEL TRIM1- 3%
OXYGEN SENSOR 2 BANK1- .445V
SHORT TERM TRIM- NOT SUPPORTED
OBD II REQUIRED- (CARB)
FUEL SYSTEM 1- CLOSED LOOP
FUEL SYSTEM 2- NOT SUPPORTED
I have (2) short trim fuels, not sure why, but thats straight from the scanner.
M
LOAD VALUE- 4.3%
COOLANT TEMP-181 *F
MAP SENSOR-14 IN.HG
ENGINE RPM- 765
SPEED-0MPH
M
