So do you have any short-cuts while working on your z34?
Here's a few of mine I've found out.
You dont have to undo the accelerator cables to move the plenum out of the way.
You dont have to unhook the fuel lines to get the fuel rail out of the way.
You dont have to move the PS pump to get the lower intake off, just use a u-joint socket on the bolt on cyl. 1
You dont have to take the exaust mainfolds off to remove the heads.
You dont have to break both cam cogs loose to time the car, just the fronts (this is assuming your timing is good to begin with)
any others??????
any others??????
