OK, I just have a couple questions. I've been in a long process of working on my 3.4 and I've forgotton a few things as far as wires. I have a wire plug on the same cluster as the ones that pop into the air filter and hose, its a small grey plug, only one prong, no idea in hell where it goes. The second one I have is a small blue one, that plugs into the lower intake, just behind the thermostat, what exactly is that for? And anyone happen to know the part number for the receptor (not the plug, but what it plugs into) mine snapped.
Then I have a couple small, solid black lines that run from the right, across the back, to a small piece nutted down to the left back plenum bolt. A red wire plugs into that same piece. My problem on that, is that I'm not sure which of the two lines go into which of the two slots.
Lastly, timing. I need a way to find TDC and the exhaust stroke.
As you can see I'm no mechanic, I sort of jumped into something over my head and this is the stuff I need to unbury myself :P
