this is a continuation of my other post about code 13.
my car is running sluggish(very), very close to stalling idling in gear. extremely slow, feels like a 2.8.
i replaced the o2 sensor - car still ran poorly
replaced fuel filter - no change
tested fuel pressure - 43+ psi at all rpm, hot, cold, under load, no load, driving. never below 43psi.
replaced coil packs and module - no change
checked plug wires for damage and arcing, no problems(less than 4k on those and plugs)
removed cat, not clogged and no change.
where do i go next? ohm out all the injectors?
