its pricy but has the 2 flats for the cams and the cam holder and gear remover... i thought i heard there were out of production!
found timing belt tools that are still being made
i forget my measurements, but roughly, 5"x3/4"x3/4" solid bar stock.
I had 2 bars made with a hole through the middle and had the surfaces machined within .004" tolerance, then blued them. It cost me $65, at a local machine shop, to have them made from a rough sketch, and $4 for the bluing to prevent rust. They are so strong I can break the bolt free and torque it again when I adjust timing.sigpicHow to make High performance Emissions:
What did you have it made out of, aluminum?Originally posted by Dave96z34 View PostI made that before it didn't work all it did was bend and crack. I have the ajustible timing tool
Mine are tool grade steel.sigpicHow to make High performance Emissions:
