Hello All
Resealing my 97 Monte Z34 oil pump drive.
I had the perverbial oil leak on top of the engine, pulled it apart and found that the oil pump drive housing AND the oil distributation plate gasket was also leaking.
I found a piece of Special High Temp. Red Silicone rubber rated at 700* and was .060" thick, I cut a disc out of it with an EXACTO knife using washers for marking templates, the washer used for the I.D. was 1 1/16" and the one for the O.D. was 1 1/2"
After removing the hold down, I installed the slicone washer on the drive housing, it streached easily and I worked it arround the housing like a rubber band, I raised the housing the 3/16" that it will raise and pushed the silicone washer under the lip of the housing, it snapped right into place and was flat. I then installed the hold down and torqued it just enough to compress the slicone washer about 1/2 its thickness and until it proturded about enough to see the red slicone rubber protuding form under the lip of the housing.
I then cleaned the housing and engine block with brake kleen and paint marked it with a stripe so that I can see it with a flashlight and inspect it once in a while to check for any movement or leakage. So far, after 1000 miles and a couple of trips there has been "NO LEAKAGE OR MOVEMENT"
This seems like a good easy fix, at least it was for me. The hardest part was getting to it.
I think that it is also good insurance to change the oil disturbution plate gasket while your there.
Hope this helps, at least it did for me.
John
John
