The car is a 1995 cutlass with 65,000 miles on it.
It began leaking oil a few months ago, but I cannot tell where it is coming from, and was hoping my limited description of the problem will ring a bell with someone.
The driveway has oil spots on it where they car is parked. I can see that the bottom of the oil pan is soaked with oil, and so is some of the framing in the same area, but I cannot trace it back to any one point.
Also, when I am stopped at a light and am running the heating/AC fan, there is the faint smell of burning oil coming in the car.
I was planning on switching this car over to synthetic oil, and in preparation for total use of sythetic used 2 quarts of Mobil 1 as part of my last oil change. The leak started shortly after that. Did I cause my own problem?
The Mobil website says synthetics do not cause leaks, but I've since seen a couple of posts that state the stronger detergents in sythetics can clean to the point of removing dirt that is sealing a potential leak.
Any advice on where to look would be appreciated.
KC
KC
