Hello everyone. I just got a Z34 with a blown motor and Im looking to build up a new one. I will have two nearly complete motors (1 with no block, 1 with no topend) to make this motor plus any usable parts from the blown motor.
I would like to try and do everything myself, with as little help from a machine shop as possible,. I will be getting an air compressor and a couple die grinders as well as a bench grinder/ polisher.
Other than a honing tool, a guage and torque wrench, What other major tools should i invest in? I have a nearly full metric and many standard nuts, sockets etc and all the other obvious necesities.
Is a really big deal to have a perfectly flat block and flat heads on this motor? or can I just grind them reasonably smooth with a disk on a die grinder and be OK? I;ve done a complete tear down and mild rebuild on a 2.2l and gotten away with using a die grinder on it but this is really different from that motor. If its too risky i wont attempt it but keep in mind I am a perfectionist and wouldnt put this together if i knew i couldnt do it.
if not i've been told i can get the block flattened, the heads flattened and the cylandars honed (not bored) for not very much money, is that true?
I am also thinking I will do a gasket match on the manifolds, plenum and heads. any one do this with just a die grinder? i've heard of ppl using dremels for this purpose but that would be a nightmare IMO.
Only other major change i will do is the exhaust cam retard. Im hoping i can get about 200 WHP out of the motor at the end of this.
