Oil in PCV
Hello All
The oil distrubation plate covers a cavity on the block where the dummy cam blank or shaft for the oil pump drive rotates, it is pretty much a sealed cavity in that the crankshaft windage and the slung off oil does not have a direct path to the PCV oil seperation baffel that is under the plate.
Exess blow-by form tired piston rings may be forcing heavy oil ladend vapor to be sucked past the PCV oil seperation baffel under the plate and thru the PCV valve and into the intake manifold.
Maybe you could do a leak down test to see if the rings are in good shape and not by-passing too much compression. A leak down test is much better than a compression test in that it uses a regulated and metered CFM volume of air to pressurize the combustion chamber with all 4 valves closed and the piston at TDC for the cylinder being checked, (Kind of hard to do sometimes)
PLEASE, PLEASE, WATCH OUT FOR YOUR FINGERS, HANDS, ETC.
THE ENGINE "WILL ROTATE/TURN OVER" IF THE PISTON BEING CHECKED IS NOT AT "TDC" WHEN THE 100 PSI OF AIR PRESSURE IS APPLIED TO THE CYLINDER.
It gives a percentage of leakdown (gage reading) of air pressure or volume lost past the rings, or valves, you can tell where the leakage is by listening to the oil filler cap hole for ring leakage, the intake manifold open throttle body for intake valve leakage or the tail pipes for exhaust valve leakage. Sometimes a 3-4 foot piece of heater hose can be held to your ear to amplify the sound of the air that is escaping.
I have talked on the forum about the oil seperating catch can before, but there is hardly any place to put it and be able to route a drain line so that the oil can drain back to the oil pan area. It sure would stop the oil in the intake problems, except on an really tired engine with an awful lot of excessive blow-by.
Another problem of using the catch can is that it would have to have a fairly large capacity for long trips and it is also effected by engine manifold vacuum. It would have to have some type of check valve that would open and allow the captured oil in the catch can to gravity drain back to the oil pan after engine shut-down.
Hope this helps
John
					Hello All
Hope this helps
John
 We could use info like that on the site!
