How ya doing? This will be my first post ever here as I just stumbled across this sight while looking for info on My 95 Monte Carlo Z34 3.4L and I think the 4t60e auto . First off its got 110000 on it, no reverse and wont shift out of 1st and makes a wierd plunking noise from near the torque conv.(Is there a good noise from that area?) So looks like Im pulling the trans unless someone might know something I dont cause I sure as hell dont know everything. ( I will post the tranny issue somewhere else )Anyway my main question is instead dropping the trans out the bottom like my haynes manual says and dealing with the suspension steering and sub frame issues I wonder if it would be worth the effort to just pull the motor/transaxle from the top in one peice? Looks like the anti lock brake system might be an issue. Like to here from any one who has been there done that. With this many miles having the motor out would be cool any way for things like altenator timing belt stuff. I have changed tranaxles 3 times on other vehicles from the bottom but not on the W body.
Better from the top or the bottom?
Looks like its going to be from the top anyway. Thanks for the replies. I thinkI will take advantage of the engine on the stand and do some of the "high maintenance" these things require like timing belt altenator and o ring. I ain't bitchin cause I REALLY like this engine.Anybody else got anything to add to the list while all the good parts are out?2004 Grand Am GT 3400 ... I had the right to remain silent, I just didn't have the ability.(Ron White)
offers a rebuild kit for $450, (the DOHC is the most expensive).
please post if anyone has experience with them.95 MC Z34 Black
If you have the tool that bolts to the engine and supports it from the top of the car it is easier to drop the sub frame out the bottom and remove the trans from the bottom. of course this is also assuming you have access to a lift.Shane "RedZMonte"
1992 Lumina Z34-VIRGIN (RIP)
1992 L67 Lumina Z34 (SOLD)
1990 Turbo Grand Prix (SOLD)
I wouldn't trust that site link you gave-it seems pretty odd. They list 91 and up 3.4L, however the different years changed a lot, and there is a difference in pistons between 5-speeds, autos, and newer years. Does that include pistons? I didn't bother looking. If so, I would definately go somewhere else.
I get my Felpro head gasket set (everything from the head gaskets up) without head bolts for $107 at Advance auto.-60v6's 2nd Jon M.
